Boot Won't Lock on My 2002 X Type
Old 12-18-2011, 01:30 AM
ez53436's Avatar
My trunk latch is a bit faulty too. What works for me is once I fully open the trunk, I unlock the trunk again and then close it shut.
Old 12-18-2011, 08:45 AM
Received 7,879 Likes on 4,763 Posts
I can't count how many I replaced/modified over the years. I tried to attach the TSB X501-04am2. There is something wrong and the attachment button will not work.
Search the sticky TSB section to find the TSB regarding latch replacement and lid modification.
bob gauff
Old 12-18-2011, 09:02 AM
It is working now!!!!
I attached!!!
bob gauff
Old 12-18-2011, 12:11 PM
If the new car factory warranty has expired, why would the dealer repair your car for free????
Generally only RECALLS are free of charge to the customer.
bob gauff
Old 12-18-2011, 01:07 PM
disguay's Avatar
Like motorcarman said, if your car is out of warranty, you will have to do it yourself. I would just buy a trunk actuator off of ebay or a junkyard. It should only be about $40-$50 and will save you a lot of headache. I had to do this on my 02 because the lock actuators on the x types are notoriously weak.
Old 02-08-2015, 06:10 AM
rogerjaguar's Avatar
I cannot open the boot on my 2002 x type saloon. The key fob operates the doors and a click is heard from the boot. The ignition key over-ride opens the doors but not the boot.
Old 01-22-2018, 07:54 AM
Twistedtrash's Avatar
Talking FIX!!!
You just need to release the actuator. Its very simple fix that for some reason no one seems to of twigged on
step 1 - remove the plastic lock caseing
step 2 - remove the lock assembly
step 3 - remove the lock actuator (the white electronic motor)
step 4 - look down the side seam of where the actuator pulls the lock mechanism in (opposite side to where u attach the wire) and you will see where the seam creates an L shape. apply a small amount of pressure to the seam around the corner of the L as if u were trying to split the houseing but without actually doing so. the actuator should release as you do this
step 5 - WD40 the actuator and push in and out a few times to get it inside the houseing
step 6 - put back together
i hope this saves a few people some money
Old 01-17-2021, 11:27 AM
AngusJam's Avatar
Hi Twistedtrash,
Thanks for your top tip here. I had exactly the same problem where the boot / luggage compartment / trunk would not lock and dash had red warning light.
I tried locking the catch manually but it wouldn't catch and stay so like you I decided the actuator must have stuck so fixed it easily thanks to your post.
Step 1 - No matter how I tried I couldn't unscrew the centre of the stoppers - with a decent screwdriver for leverage I popped both in 2 minutes, and then you can just push out the screw ready for easy refitting. (Before I tried brute force I spent 45 mins trying to get the screws out the centres.....)
Step 2 - Luckily I had a torque? 30 head to get the 3 lock screws loose - I loosened two and before the third disconnected the electrical catch.
I put silicon spray on the outside thick part without taking the actuator apart and it seems to run just fine (I note others** took it apart and freed inside though)
** https://www.jaguarforum.com/threads/...se-lock.78848/
Best regards Angus (Working on friends X-Type 2004)
Derek Lake
XF (X260)
10-23-2019 12:23 PM
XtypeHI
01-02-2019 07:06 PM
new mexico
08-07-2018 04:24 PM
jmattila
07-10-2014 09:44 AM
sacrider
12-30-2009 01:38 PM
Quick Reply: Boot Won't Lock on My 2002 X Type
