brakes sensitivity
brakes sensitivity
i get my jagyar x-type 2005 with 2.0 litre diesel engine to the jaguar garage for service,after i take my car back i push the brake pedal to the end and the car dont want to stop,i go back to the garage and they change the oil pump of the brakes and again the car dont want to stop,i go for 3rd time to the garage and finally it change the tube which is send oil at the brakes...finally the brakes works but they loose the sensitivity and the smoothnes have before this problem
Hi Akonas,
Kalimera or Kalispera, A Big Welcome to the forum and hope you get sorted here, Your fellow members are great and I wish you luck too!
I have looked at your other post and think you will need an OBDII scanner to find the fault?
Then you can get the codes and post back, at best the problem may be your cam position censor but hard to tell further.
Are you seeing any lights on the dash? I would have said fuel filter for the stalling or spluttering but it sounds like you have a serious issue with the breaks, be careful?
Plus, you need to go to New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum
and introduce yourself, adding your your model/engine and spec to your signature will help too, whenever you post and this will help for the future.
If these issues are related, have a look at this post:
https://www.jaguarforums.com/forum/x...d-start-91134/
Good Luck, Stu
Good Luck, Stu
Received 3,822 Likes
akonas, I would first check to see if the check valve for the brakes is still good (the tube that runs from the top of the engine over to the brake booster cylinder). If that has suffered a little bit of damage (the plastic gets weak with age and is prone to cracking), that can result in what you are seeing. After that, I would be looking at getting the brakes bleed somewhere else as a little bit of air in the system can lead to big issues. Between these two things, you should be back on the road. If this doesn't fix your issue, then I would be finding another shop to do work on your car as it sounds like they are not doing much good for you.
Stuart Beattie (04-18-2014)
xjrjag
09-24-2015 10:08 PM
