A/c not working
Old 08-27-2014, 08:22 AM
jagrod's Avatar
Default A/c not working
I got my 2002 jaguar x type 3.0 recently and a/c was working fine at first. Then recently it stopped working all of a sudden. It powers on but no air blows out. Any help on how to fix this. Also the handbrake is not working either as ican pull it up completely and it wont catch on to anything. Can someone point me to some replacement parts?
Old 08-27-2014, 05:18 PM
Dr dome's Avatar
I am sure I have what you need. Ok first it sounds like your blower motor is out. Check the fuses. I don't have the book right now to know what fuse. Second.You need to jack up the back end of the car and look at the back end of the brake caliper. You will see a cable with a spring attached. Make sure it is attached to the back of the caliper.(if its not that's your issue) if it is Have someone pull up on the brake to see if it moves. If it does not move you have a busted cable under the car. Look under the car just before the prop shaft bearing. There is a clip that holds both left and right cables. Look to see what cable is broke. Pm me and we can talk about what you need and prices. I have shipped many parts all over the us and even a few to Canada. All my parts are in good to great shape or I do not sell them. Let me know,
Good Luck,
The Dr!
Jeh
XJ40 ( XJ81 )
10-13-2015 09:23 PM
tberg
09-07-2015 07:32 AM
daverb
09-05-2015 12:53 PM
philwarner
09-05-2015 10:05 AM
OkieTim
09-02-2015 12:48 PM
Quick Reply: A/c not working
