Cam Belt
Old 11-20-2010, 07:00 AM
oldtimer's Avatar
Default Cam Belt
HI
Have just bought 93 X type 2.0D.
Can't find out when cam belt if it has one should be changed, does anyone know the answer?
Old 11-20-2010, 07:05 AM
steve11's Avatar
ud
Do not believe it has a belt. We don't see the diesel here in the States, so I'll defer, but to my recollection, Jaguar does not use timing belts in anything.
Old 11-20-2010, 12:47 PM
The X-type (petrol) does not use a timing belt, it uses chains. That said, there was no X-type in "93". Maybe you meant "03"?
Old 11-20-2010, 12:49 PM
Received 6,242 Likes on 5,443 Posts
That's my feeling too Steve, Oldtimer if you head over to the X section you will geyt the answer, on the S type you can see the cam chain through the oil filler hole.
Old 11-20-2010, 12:59 PM
steve11's Avatar
ud
I'm sure of all models/years in NA back to the SII because I've worked on just about every one. It's the diesel part, which we techs just don't see in NA. In fact, I don't even have any technical info or data on it. As Jagtec says though no such animal as a 93 X-Type, but I'm betting it's an 03 X-Type with a "slip of the typing finger" by one key.
Old 11-21-2010, 05:24 AM
oldtimer's Avatar
Yes, its a 03. Not too good at this typing lark!
Old 11-21-2010, 02:53 PM
Fraser Mitchell's Avatar
Received 2,424 Likes on 1,937 Posts
The X-Type diesels are made by Ford. I don't think they have a cam belt, but to allay all doubt, get hold of the servicing schedules, because cam belts normally need to be replaced at a fixed time interval of about 5-6 years, OR at a mileage, usually between 60-90k, manufacturers vary in their recommendations.
Also have a close look at your car's engine. A Cambelt is usually covered with a pressed steel cover; a camchain will be buried in the front of the engine as it runs in oil.
Old 11-22-2010, 11:26 AM
victor's Avatar
I'll check tomorrow. The S type diesel uses a belt, (change at 105000 miles or 10 years, Jaguar figures) AND small chains which are internal and maintenance free.
Old 11-23-2010, 05:51 AM
oldtimer's Avatar
Default cam belt
Great, thanks.
Old 11-24-2010, 05:49 PM
Leedsman's Avatar
Yes, cambelt change needs a mileage figure. The previous owner may have changed it, so you need to get hold of him/her and find out. No sense in spending money without justification. Modern cambelts can be rated to 150,000mile, it all depends what's been fitted to yours. You are of course aware of the damage a snapped cambelt can cause? It will write off the cyl. head -- VERY painful in the wallet. It happened to me. After a while, I realized the car (Audi) was an economic write-off.
In case anyone is wondering, I can state that the belt used in the 2.7D for instance is colossal, about twice the width you'd expect.
Leedsman.
MrWhite
19
06-14-2022 07:49 PM
04Xjrsteve
05-07-2019 04:06 PM
Col. Sandurz
09-28-2015 07:29 PM
42Ajd
09-26-2015 07:04 PM
Quick Reply: Cam Belt
