Cannot remove road wheel ?
All lug nuts way loose, but wheel will not move off center location to hub.
Any suggestions....I'm guessing corrosion here.
Never encountered this problem before...always changed winter/summer wheels without problem for years now.
Thanks,
Rob
2006 X Type Sport Wagon.
1987 XJ6 DD.
1994 XJS 6.0 Convertible.
Thanks,
Rob
1987 XJ6 DD.
OK. Problem solved.
Was concerned about "wacking" the extremities of the wheel...potential wheel bearing damage.......so...removed center cap...use medium claw hammer against inner lip of center cap hole and end of the wheel stub axle (thread is nicely undercut here, so no thread damage)...use long cheater bar (tube actually) and lever wheel off...works like a charm.
Can't find the camera at the moment..I'll try to post a few photos later.
Thanks,
Rob.
Thanks,
Rob.
Received 3,825 Likes
1100me (12-01-2014)
And if you don't like the sight of copper grease on your alloys, Land Rover dealers stock this product:
ZETA GREASE is an aluminium based anti-seize. Same colour as the wheels!
1100me (12-01-2014)
Received 2,255 Likes
1100me (12-01-2014)
Received 9,005 Likes
1100me (12-01-2014)
Next time, leave the lugnuts loose a turn or two and lower the car back onto it's wheels. Drive it back and forth a bit (slowly) and the wheel will come loose.
I am aware of this working very well after a friend found that his large hammer only dented his wheel.
1100me (12-01-2014)
Received 10,757 Likes
+1 on the smearing of grease to prevent future seizures.
Personally, though, I've never used anti-seize or any special grease for this purpose. A little smear of whatever wheel bearing grease you have on hand or whatever is already in your grease gun will do the job perfectly well.
No need to use anything special. Unless you want to, of course. In that case, by all means, go ahead
1100me (12-01-2014)
hunter34
19
09-14-2022 11:09 PM
MC36
US Lower Atlantic
09-01-2015 07:34 PM
