check engine light wont go off
Received 3,825 Likes
Based on the code, you are suffering from either a failed TCM module or the CAN bus wiring to the TCM is damaged and therefore not communicating like it should. Odds are, you would be best served by taking it to a shop and having them connect up a high dollar computer to see if they can talk with the TCM. If they can, then odds are you have a TCM failure. If they can not, then most likely a CAN Bus system failure.
jaguar0206 (07-29-2014)
where the TCM located
thanks for all the information great information so where is the TCM located?
BrentGardner
26
04-17-2024 05:19 PM
