auto box repair
Old 08-12-2014, 08:08 AM
fourbyfourbyfar's Avatar
Default auto box repair
Hi All just started the removal and repair of my gearbox. started taking out the transfer case and disconnecting the drive shaft some thick oil came out of the joint is this right??here is a picture of the oil leak
Old 08-14-2014, 03:12 PM
alan924's Avatar
No its not right. You have oil leaking out of the transfer box via the splines of the drive flange. To cure it when re-assembling put sealant on the output shaft before fitting the flange and again on the shaft before fitting the large nut. There is a TSB covering this, cannot remember the number at the moment.
Old 08-14-2014, 08:25 PM
Received 7,862 Likes on 4,752 Posts
Here is the TSB issued for the early cars.
bob gauff
File Type: pdf
Old 08-18-2014, 05:10 AM
i thought is was a bit odd thanks for the TSB will do that on the bench when i take the transfer case out
tomsjag
06-10-2023 10:02 AM
cissdm
05-03-2016 06:02 AM
1964Daimler
10-03-2015 12:18 PM
Doovoe
09-08-2015 05:42 PM
brgjag
US Midwest
09-04-2015 11:24 AM
Quick Reply: auto box repair
