completely confused
Old 12-14-2010, 01:02 PM
jonsjag's Avatar
Default completely confused
can anyone tell me if the valve cover gaskets are the same on both the 3.0 and the 2.5 . im working with a 2003 type x. and is there a ford vehicle i can look up to buy these at a decent price verses buying at the local dealer.
Old 12-14-2010, 04:46 PM
j_bond's Avatar
likely the gaskets from a mazda6 V6 or lincoln LS V6 will work fine. good possibility the Ford Contour Sport 2.5 or 99+Mercury Cougar 2.5 will work as well
jonsjag (12-15-2010)
Old 12-15-2010, 04:22 AM
I <3 X-Type's Avatar
JBond....i could be wrong but...our jaguars (x-type) have the water pump driven off the cam coming off the radiator/battery side head. So im not sure if it would work. Again, i could be wrong but i believe when i used the Lincoln LS engine i had to reuse that side gasket and valve cover. The LS engine has the waterpump elsewhere, so maybe rule out the LS. You may be right about the others!!!!!
Just a thought
Old 12-15-2010, 10:23 AM
Tony_H's Avatar
This indicates they're the same for both engines:
http://www.britishparts.co.uk/.sc/ms...20Type--Engine
They're $7 each, so why are you worried about prices????
Old 12-15-2010, 11:28 AM
jonsjag's Avatar
i want to thank you all for you help with this. but i think rather than to take the chance, i am going to go to the local dealer today and pick up the gaskets. cant go wrong that way,,,,,, right? lol.
Old 12-15-2010, 01:18 PM
exrub's Avatar
Right. Better safe than sorry. Good luck!
Old 12-15-2010, 05:26 PM
steve11's Avatar
ud
Jaguar cam cover seals are NOT compatible with any Ford Lincoln, Mazda variations because the heads Jaguar used are unique to its Duratec variation with VVT. So, you're right going to a Jaguar dealer or an aftermarket that sells Jaguar pns.
Old 12-15-2010, 10:21 PM
Steve11...despite the accessories to being unique model years, they are basically the same engine in some of them. For instance, i used a 2004 Lincoln LS engine for my Jag. They share the same VVT. Thats basically what he was saying. The most similar is the Lincoln LS. Only difference is some external locations of accessories.
bdboyle
09-16-2019 05:58 PM
Poet
06-07-2019 07:54 PM
perezal
12-24-2015 04:16 PM
PinnacleWax
Detailing / Car care
09-25-2015 12:46 PM
vacolorito
09-25-2015 09:29 AM
Quick Reply: completely confused
