Coolant reservoir hose-again
Old 01-21-2015, 02:33 PM
Spikepaga's Avatar
Default Coolant reservoir hose-again
Hello everyone!
I changed this hose 6 months ago. Now it's spraying coolant all over the car again, in considerable amounts right where the T clamps to the other hose. Its Also dripping At the reservoir clamp. Tightening has not helped:
Is this happening because it's an aftermarket hose?
Always coolanr leaks with this car! Driving me nuts
Old 01-22-2015, 09:54 AM
hammerma68's Avatar
Just a hunch, but maybe new hose clamps would help. Is there any oil in coolent or coolent in oil? Maybe head gasket or ? pressurizes coolant system?
Old 01-22-2015, 10:20 AM
Spikepaga's Avatar
Thanks for your reply.
I tried new clamps and that has not helped.,
Not too sure how a faulty head gasket would cause the hose to spray coolant at the joint though.
Thoughts?
Old 02-08-2015, 11:48 PM
Ashlita's Avatar
Did you ever get this fixed? Mine is doing the same!!
Old 02-09-2015, 07:39 AM
mrplow58's Avatar
Try changing the clamps, and a full coolant change. You may also have a faulty coolant reservoir cap, that is not releasing pressure, or a T fitting with a small crack....Be cool......Mike
Old 02-09-2015, 09:37 PM
Spikepaga's Avatar
Yes, the problem was the cheap aftermarket house::
https://www.jaguarforums.com/forum/x...months-135444/
MrWhite
19
06-14-2022 07:49 PM
Poet
06-07-2019 07:54 PM
X308XJR
05-20-2019 06:50 PM
Gregory Neil O'Rear
09-29-2015 09:52 AM
Quick Reply: Coolant reservoir hose-again
