Go Back   Jaguar Forums - Jaguar Enthusiasts Forum > Jaguar Models > X-Type
Sign in using an external account
Register Forgot Password?
Search
X-Type 2001 - 2009
LinkBack Thread Tools Search this Thread
Old 03-30-2009, 09:43 PM
chattiml
Guest
Posts: n/a
Default Coolant Temperature Sensor Location
Can someone tell me where to find the coolant temperature sensor on a 2003 X-type 2.5? Thanks!
Old 03-31-2009, 06:59 AM
ud
not exactly sure.. but if you are reacting to strange behaviour of the temp gauge, make sure you know this first.
THe gauge does not display what the temp sensor is reading..
the gauge signal comes from the engine computer, and it is a massaged signal.
It is programmed to stay pointed dead centre as long as the temp is normal.
if your gauge is acting strangely then most likely you are having out of normal temperatures.
Thermostat is most likely issue on X-Type.
I am only guessing about your post, but I was thrown by my gauge, I suspected a temp sensor problem, but it turned out to be the thermostat.
Old 03-31-2009, 08:36 AM
jfenley's Avatar
There are several FUSES to check but I do not remember which ones, maybe 3,5,9. These will have to do with modules and the fans. My suggestion is to get a copy of the JTIS. It has loads of procedures to TEST and diagnose your cooling system.
In the diagram below one black arrow to FUEL sensor and the other is the Water Temp sensor.
Click the image to open in full size.
__________________
02 X-type 3.0l
04 S-type 3.0l
07 X-type 3.0l
See the complete saga in picture format
http://s601.photobucket.com/albums/tt96/jfenley123/
also for more info
http://www.drivehq.com/web/jfenley/
HAVE FUN!! and ENJOY the RIDE
Old 03-31-2009, 06:41 PM
chattiml
Guest
Posts: n/a
Thanks all. The diagram is exactly what I needed jfenley. The reason behind this is I was getting a check engine light along with a P0116 code. So after reading several posts in the forums I figured I'd just replace the cts since its very inexpensive and an easy change. I've done the work and will take out for a drive soon.
Is there any chance this will also clear a P0174 Lean code or will I likely need to have the O2 sensors replaced?
Old 03-31-2009, 10:03 PM
jfenley's Avatar
I do not know if ECU cares how hot or cold the engine is running to mix air/fuel. It would really be a complicated program of comparing sensor data and then tabulate the air/fuel ratio. What I do know is that the O2 sensors are responsible for telling the ECU that the vehicle needs more air or fuel. The O2's in conjunction with the CATs make it run lean or rich. The danger of a bad O2 is that your are in danger of saturating the CATs and they are very costly. O2 are not cheap but reasonable as far as Jag parts prices go. Also if your CAT becomes saturated it will foul and damage your O2 sensor over time and you will be right back where you are now.
__________________
02 X-type 3.0l
04 S-type 3.0l
07 X-type 3.0l
also for more info
Old 04-02-2009, 09:19 AM
ud
Most common reason for lean code on X-type is unmetered air getting into the intake manifold... cracked hose or orings leaking.
Tags
30, coolant, cooling, diagram, engine, gauge, jagiar, jaguar, location, sensor, system, temperature, type, xj8, xjr
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Copyright © 2010 Internet Brands, Inc. All rights reserved.
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013 vBulletin Solutions, Inc. All rights reserved.
SEO by vBSEO ©2010, Crawlability, Inc.
JAGUAR and its logo are the registered trademarks of Jaguar Cars Limited. Jaguar Cars Limited is not affiliated with JaguarForums.com.
