Go Back   Jaguar Forums - Jaguar Enthusiasts Forum > Jaguar Models ( Modern ) > X-Type
Sign in using an external account
Register Forgot Password?
Search
X-Type 2001 - 2009
Welcome to Jaguar Forums!
Welcome to JaguarForums.com.
You are currently viewing our forums as a guest, which gives you limited access to view most discussions and access our other features. By joining our community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join the Jaguar Forums community today!
cruise not available
LinkBack Thread Tools Search this Thread
Old 01-09-2007, 05:26 PM
Guest
Posts: n/a
Default cruise not available
2002 X-type - 62k. No problems before this. Now I have an intermittent message: Cruise Control Not Available.
But... Cruise control works fine. Message comes on every few minutes but Check Engine light remains on.
I changed the battery about 6-weeks ago. But electronic bugs cleared up within the first day. Checked all fuses and connections. Everything good and tight.
Any idea what's going on? or... how to reset the system without a trip to the Dealer. I do all the maintenance myself. - Thanks
Old 01-09-2007, 09:45 PM
bojangles
Guest
Posts: n/a
Default RE: cruise not available
i only go that with the check engine light.. turns out the thermostat was acting up and the car was running hot then cold... that set the check engine light then occasionally the car went into limp mode and that gave the message cruise not available..
has not happened since the new thermostat.. but the point of this message is that you should probably find out what is setting the check engine light..
changing the battery should not cause any problems... just the radio code and the toll feature on the power windows..
Old 01-09-2007, 11:28 PM
Cruise unavailable is just a soft code, meaning that there is a bigger issue that has yet to show itself. The reason it says cruise unavailable is so that if your jag goes into limp mode your not locked into a high speed. When your jag goes into limp mode it locks itself in 3rd gear...If your on the freeway, in cruise, doin 75 then down shifting into 3rd gear would be not good...
Sounds like your gonna need to get your jag diagnosed??
Old 01-09-2007, 11:39 PM
could have a sub processor failure. the pcm has 2 processors. the main (outside processor) and the sub processor (this controls throttle and cruise)... it could be a simple patch file that needs to be loaded. you will have to find someone with wds/ids to diag it for you. or take it to the dealer.
without pulling all codes, you are just guessing at it! it could also be a bad battery. the negative terminal likes to crack and corrode on the xtype and can cause some voltage related issues.
__________________
Jaguar Gold Master Certified Technician
ASE Certified Master Technician
www.jaguarftpierce.com
Old 01-10-2007, 04:24 PM
Photobucket
Send a message via MSN to JimC64 Send a message via Skype™ to JimC64
Click the image to open in full size.
Hmmmmm gettin cruise not available?
Me too, cos I dont have it[]
I NEED to get it fitted ASAP.
Any help out there appreciated as Chris seems to have gone AWOL
Jim C
__________________
Jim
Nothing is foolproof to a sufficiently talented fool!!
A fine is a tax for doing wrong, A tax is a fine for doing well......
MY2008 (58) XJ X358 2.7 Tdvi Sovereign LWB remapped to 245bhp, Black, Ivory leather interior with black piping, 20" Alloys
MY2007 Audi A6 3.0 Tdi SE Quattro 176bhp Stratos Blue, Front & Rear park assist, Comms Pack High, Sline grille badge, 19" 7 twin spoke RS4 alloys,
Rear tints,
Dipped bulbs 80W, Mainbeams 100W, Foglights 100W, Number plate bulb LED's, Interior bulb LED's, First Aid Kit
LANG MAY YER LUM REEK
**********************Contact-Admin // Forum-Rules // New-member-Must-Read // Vendor-directory**********************
If you've been helped, please click on the "Thanks" button
Old 01-10-2007, 09:38 PM
Come'on, its a jag, were in the new millenium, and cruise is an option not a standard...that just makes me sick[:'(] What next, power windows as an option??
Old 01-10-2007, 10:13 PM
bojangles
Guest
Posts: n/a
keep in mind that mercedes are the taxi of choice in most of the world.. they are good long life cars, low long term running costs and certainly are not loaded with accessories for taxi duty.
only the US demands accessories..dominate as the americans are.. they are not the world majority.
I wish that more euro cars were available stripped down and afordable. If you want acheap car here you need to drive something crappy.
that being said.. my car is loaded with everything EXCEPT auto transmission
Old 01-10-2007, 11:02 PM
Photobucket
Ohhhhhh........listen to Andersen...(slap) goin on about cruise control an how he's got it.....lol
Well, Bo's right........only in the states do you guys demand everythin as std.......over here we have lower standard base models then lots of possible options, which means you can buy exactly the car you want, or indeed the car you can afford!
Therefore you end up with many more possible choices than I guess you guys have.
Anyway Andersen, stop bein b*tchy, its not like you.
Did you get outta wrong side of the bed this am or what?
Oh yeah.........I've got bright lights and can at least see where the h*ll I'm goin....... whats your excuse?.........lol
Jim C
__________________
Jim
Rear tints,
Old 01-11-2007, 12:02 AM
Its easy to forget some of you are from across the pond. And us americans have been spoiled by many enjoyments. I would love to buy my cars the way you guys do, but I dont make the rules. And Im just saying...Cruise should never be a option, It should be a standard. Leave the options for cup holders and heated seats(which I have).
Old 01-11-2007, 12:15 AM
Photobucket
Quote:
ORIGINAL: andersen06
You're right to a point I guess andersen.........anyways I need to get cruise retro fitted for those longer journeys. Big time!!
No heated seats either, but it doesn't get that cold over here......"lying thru teeth"
Jim C
__________________
Jim
Rear tints,
Old 01-11-2007, 12:26 AM
Photobucket
If I remember rightly the coldest it got over here was -18 but that was a few years ago. I remember cos I had to put a jumper on over my t shirt. Not cold enough for heated seats.........lol
Jim C
__________________
Jim
Rear tints,
Tags
2002, available, code, contorl, control, cruise, jaguar, limp, mode, problems, reset, soft, type, unavailable, xj40, xtype
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Copyright © 2010 Internet Brands, Inc. All rights reserved.
Powered by vBulletin® Version 3.8.7 AC1
Copyright ©2000 - 2015 vBulletin Solutions, Inc. All rights reserved.
JAGUAR and its logo are the registered trademarks of Jaguar Cars Limited. Jaguar Cars Limited is not affiliated with JaguarForums.com.
