The Definitive Coolant Bleed Procedure
Old 10-22-2014, 09:29 AM
That Geezer's Avatar
Default The Definitive Coolant Bleed Procedure
Hi Folks,
I hope you're all well.
I am looking for a line by line guide to bleeding the coolant system, there are bits here and bits there, people being smart and others not so.
Basically I had a water leak from the water pump to the engine, i replaced the lost coolant, about 3 liters. I used the bleed screen on the water pump to expel air from that side of the system but my temp gauge on the dashboard is now showing 1/4. Strangely if i turn off the car and turn it back on again the temp shows the true temp in the mid position but then the gauge drops back to a 1/4 within seconds.
Please give a line by line guide EG:
  1. remove filler cap
  2. turn on car
  3. turn on heater to full
  4. ........
Thanks Peeps
Old 10-22-2014, 12:08 PM
dwclapp's Avatar
Thermo's definitive guide to "burping your kitty" is post #10 in this thread:
https://www.jaguarforums.com/forum/x...-x-type-28628/
That Geezer (10-22-2014)
Old 10-22-2014, 03:05 PM
3lvis's Avatar
When I fixed a leak from my thermostat housing I just filled her up, let engine run for a little bit, filled to max and because she was on jack stands I lowered passenger side first (LHD), alot of air came out, then driver side and filled up again. No air, no leak, no problem.
Old 10-22-2014, 04:56 PM
Hi is this for the transit opps diesel?
Mac Allan
07-20-2020 05:46 PM
RaceDiagnostics
04-04-2016 04:00 PM
vwbusbits
10-13-2015 03:43 AM
Johncy2000
10-02-2015 01:05 AM
Quick Reply: The Definitive Coolant Bleed Procedure
