Door 'Guard/Trim/Strip Removal Project....
Old 03-26-2011, 10:44 AM
j_bond's Avatar
I'm still going to try it. If the holes are small enough, I will fill them and have it airbrushed. How big are the holes Jeremy?
Old 03-26-2011, 01:35 PM
exexpat's Avatar
I would guess 4-5mm in diameter. It's just a little guide pin to ensure alignment of the rub strips.
Old 03-26-2011, 06:46 PM
ghettomike's Avatar
so you have the fronts off but not the backs???
lets see some pics.
Old 03-26-2011, 08:35 PM
j_bond's Avatar
Project TERMINATED.
The guide pins and the indention where the guards are removed does not look satisfactory
onto the next.....
Old 09-11-2011, 12:38 AM
JasonERF's Avatar
Originally Posted by j_bond
Project TERMINATED.
onto the next.....
Could you clarify what you mean by indentation ?
There's more than just the holes? The body work indents around it?
I'm assuming to do this right you'd have to be properly repainting and filling in the holes before hand?
Old 09-11-2011, 02:31 AM
Received 4,436 Likes on 2,421 Posts
If you stand behind your car, looking down the side, you can see that the door skins are "scalloped" i.e. long sweeping curves, but the center section where the trims are is slightly raised & flat. The shape of the door skin is interupted where the trim is. So when you take off the trim, you can clearly see where it was. Oh, and the holes!
Old 09-11-2011, 10:48 AM
JasonERF's Avatar
Ah, yes. Thanks!
99xk8guy
06-05-2023 06:28 AM
kevinl
10-31-2019 06:15 PM
99xk8guy
09-21-2019 07:34 PM
dsnyder586
04-04-2019 02:38 PM
sadepol01
09-11-2015 05:26 AM
Quick Reply: Door 'Guard/Trim/Strip Removal Project....
