Go Back   Jaguar Forums - Jaguar Enthusiasts Forum > Jaguar Models ( Modern ) > X-Type
Sign in using an external account
Register Forgot Password?
Search
X-Type 2001 - 2009
Welcome to Jaguar Forums!
Welcome to JaguarForums.com.
You are currently viewing our forums as a guest, which gives you limited access to view most discussions and access our other features. By joining our community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join the Jaguar Forums community today!
Door won't open
LinkBack Thread Tools Search this Thread
Old 09-21-2009, 03:47 PM
justcoolin
Guest
Posts: n/a
Default Door won't open
I have an 03 x-type and drivers door will not open from the outside. It will open from the inside. How annoying! Any suggestions on a fix...
Old 09-21-2009, 08:40 PM
Thermo's Avatar
coolin, sounds like the bar between the outside handle and the latch mechanism is broken. THat or the outside door handle is having issues. Unfortunately, the only way to figure out your problem is to pull off the door panel and then look at what is going on. From there the answer will be pretty self evident.
__________________
Chris "Thermo" Coleman and K'Re Ann, the 03 X
Old 09-22-2009, 01:23 AM
mohrd's Avatar
I had this problem once. If you push on the door just above the handle, you may hear a "click" that re-engages the latch. Then the handle may work. If not, looks like you are taking the panel off and seeing what's come unattached. perhaps the plastic clip others have had issues with.
__________________
Loved my '02 X-Type, 3.0 Sport, Platinum on Warm Charcoal,18" Proteus wheels, minor mods. Now she is loved by another.
The Following User Says Thank You to mohrd For This Useful Post:
timetraveler1 (05-24-2013)
Old 09-24-2009, 05:45 PM
I had this same problem. Had to leave my window down to open the door. Expensive fix for me since I pulled on the outside handle too hard and broke it. It ended up being something simple. My buddy that works at the dealer said it's a common problem for x-types. All I had to do was lube up the locking mechanism or latch on the door. It tends to get stuck sometimes. I lubed it up and works like a charm. Shuts more smoothly too. I used white lithium grease instead of WD40 since it lasts longer.
Old 09-24-2009, 06:09 PM
queenmb's Avatar
Exclamation
Quote:
Ive heard that this is a common problem too. Mine has started doing the same thing sometimes. Stiffler, exactly how did you lube up the locking mechanism. Did you just spray into the lock or did you have to disassemble something?
__________________
2002 X Type 3.0 Sport
2007 MB CLS550 7 Sp Shiftable Auto
______________________________________________
Old 09-24-2009, 08:24 PM
Photobucket
Send a message via MSN to JimC64 Send a message via Skype™ to JimC64
Click the image to open in full size.
Guys, as posted, a common problem, especially on the older x types.
Check out the X type FAQ quick link as it should be fairly well documented.
There is also a how to for removal ( with pics ) for the door card
__________________
Jim
Nothing is foolproof to a sufficiently talented fool!!
A fine is a tax for doing wrong, A tax is a fine for doing well......
MY2008 (58) XJ X358 2.7 Tdvi Sovereign LWB remapped to 245bhp, Black, Ivory leather interior with black piping, 20" Alloys
MY2007 Audi A6 3.0 Tdi SE Quattro 176bhp Stratos Blue, Front & Rear park assist, Comms Pack High, Sline grille badge, 19" 7 twin spoke RS4 alloys,
Rear tints,
Dipped bulbs 80W, Mainbeams 100W, Foglights 100W, Number plate bulb LED's, Interior bulb LED's, First Aid Kit
LANG MAY YER LUM REEK
**********************Contact-Admin // Forum-Rules // New-member-Must-Read // Vendor-directory**********************
If you've been helped, please click on the "Thanks" button
The Following User Says Thank You to JimC64 For This Useful Post:
paulmcgouran (03-06-2013)
Old 09-25-2009, 10:57 AM
Quote:
I didn't have to disassemble anything. Just spray into the latch. (not where you put the key in obviously)
Old 12-13-2009, 05:37 PM
smokeonthwatr
Guest
Posts: n/a
had this same problem on my 2002 xtype and if you push on the door just above the handle...you will hear a click and it works after that.
Tags
2000, broken, door, driver, handle, jaguar, open, opening, problem, stuck, type, wont, xj6, xjr, xjs, xtype
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Copyright © 2010 Internet Brands, Inc. All rights reserved.
Powered by vBulletin® Version 3.8.7 AC1
Copyright ©2000 - 2015 vBulletin Solutions, Inc. All rights reserved.
JAGUAR and its logo are the registered trademarks of Jaguar Cars Limited. Jaguar Cars Limited is not affiliated with JaguarForums.com.
