Flashing amber warning light
Old 10-24-2014, 09:08 AM
cb4842's Avatar
Default Flashing amber warning light
Hi Guys,
I wonder if anyone has had a similar issue or knows what the issue is.
I went out for a drive this morning and the amber warning light started to flash erratically and intermittently with no message displayed, this continued for about 10 min's then stopped. there was no noticeable fault with the drive of the car. The car had been out about an hour earlier without an issue.
It is a 2004 2.0D SE estate.
Thanks in advance
Craig
Old 10-24-2014, 10:24 AM
dwclapp's Avatar
Craig: Suggestion: Turn the ignition key to the on position to activate all the dash lights and take the picture in the few seconds the lights are on. Circle the amber light in question and post the picture here. Someone will know.
Old 10-25-2014, 09:21 AM
Dr dome's Avatar
Default light
I think he is talking about the amber light above the message center.
Old 10-25-2014, 09:24 AM
cb4842's Avatar
Default Pic added
Yes Dr Dome that's the one I'm referring to, I have circled it in the pic.
Craig
Old 10-25-2014, 10:15 AM
Lcgi's Avatar
Arrow
Hi Craig,
The amber (warning) light you refer to is to indicate to you that the Diesel Particulate Filter (DFP) is full - and requires regeneration.
See that attached;
Hope this helps.
Old 10-25-2014, 12:39 PM
Five Speed's Avatar
Take it for a fast , long run see if you regen & burn the gunge out of the DPF. Make sure you do this once in a while to keep DPF working properly
Old 10-26-2014, 04:19 AM
cb4842's Avatar
Default Thanks Five Speed
There is no message in the display to indicate this and the light was flashing erratically. I will give it a blast though to see if it changes anything.
Craig
Old 03-26-2016, 09:08 AM
G1985's Avatar
Originally Posted by cb4842
Hi Guys,
Thanks in advance
Craig
Well I'm facing the same issue for the last couple of days.Just carried out a code reading,needless to say,there is none.After several ours of investigation I realised that I've seen the amber light flashing last time when the traction control was working a lot in the winter months.Took mine for a spin and when it started to flash the amber light I switched off the traction control and suddenly everything went back to normal.I suspect one of my rear sensors are faulty...
Hope it helped!
Old 04-05-2016, 01:52 PM
G1985's Avatar
Hi Guys,
Thanks in advance
Craig
There's no DPF in our cars...
JarodL
03-07-2024 01:39 AM
D.K
12-10-2023 02:05 AM
Jpav27
07-31-2022 06:43 AM
99xk8guy
09-21-2019 07:34 PM
edtexas
09-04-2015 08:20 PM
Quick Reply: Flashing amber warning light
