Go Back   Jaguar Forums - Jaguar Enthusiasts Forum > Jaguar Models ( Modern ) > X-Type
Sign in using an external account
Register Forgot Password?
Search
X-Type 2001 - 2009
Welcome to Jaguar Forums!
Welcome to JaguarForums.com.
You are currently viewing our forums as a guest, which gives you limited access to view most discussions and access our other features. By joining our community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join the Jaguar Forums community today!
LinkBack Thread Tools Search this Thread
Old 10-03-2012, 09:54 AM
Default front passenger door lock/unlock
Hey guys
I just found that the front passanger door does not lock/unlock with the remote, also if I manually lock/unlock the driver's door does not do anything and to make things more weird if I manually unlock/lock the passanger's door then all doors respond.
If if unlocked when the car moves does not lock either.
There's no problem with any of the other ones.
What type of pain this is?
Old 10-03-2012, 03:13 PM
disguay's Avatar
Bitz31
verdugo, I have had many locking problems on my xtype and I've finally gotten them all figured out. I would like you to be a little clearer though in your description of your locking problem so myself and other members can help you out.
This is a little easier to understand. ie.
Unlock the car via keyfob: passenger door does not respond
Unlock passenger door by hand: All locks respond
Unlock driver door by hand: Passenger lock does not respond
__________________
2002 3.0 sport 5spd with 128k and counting...
Currently on 18's, lowered, with SPC rear UCA's, dual resonator delete, and some bump (2 12's) in the trunk!
Old 10-03-2012, 05:58 PM
Got it!
Unlock/Lock door via keyfob: front passanger door does not respond
Unlock/Lock drivers door by hand: all locks respond but front passanger 1
Unlock/Lock front passanger door by hand: all locks respond
Autolock while car moving: all locks respond but front passenger 1
Old 10-04-2012, 09:10 AM
mobilextc's Avatar
MobileXtC MobileXtC
This car has one of the most confusing unlock/locking mechanism but try this.
In order for the key fob to unlock all doors you have to press the unlock button twice. It is the same with using the key to open all doors, you have to turn the key twice within a second or so.
You cannot lock the doors if engine is running, safety feature to prevent you locking your keys in the car but if there is another passenger in car they can lock themselves in.
So press key fob 1 time for driver door and twice for all doors
Turn key in driver door 1 time for driver door and twice for all doors.
__________________
MobileXtC - 2002 Jaguar X-Type 2.5 V6 Manual 5 Speed 94,000 miles
Old 10-04-2012, 12:03 PM
emaraszek's Avatar
emaraszek emaraszek
I'm no expert here but it sounds like there is some sort of issue with your front passenger lock receiving the signal to lock from another source. Maybe there is a loose/damaged wire somewhere that prevents that specific lock from receiving the lock command. However, it seems like it is still able to send the command to other locks.
I would probably start by looking at the wiring for that lock. I've never had this issue before but maybe other members will have the answer. Good luck!
__________________
Evan Maraszek
2014 BMW 335i xDrive
2005 Jaguar X-Type VDP - Sold
JCNA Member
The Following User Says Thank You to emaraszek For This Useful Post:
verdugo (10-04-2012)
Old 10-04-2012, 01:00 PM
I meant to say, when I turn the engine on and the car reaches a speed equal or higher than 5mph all locks actuates except for the passenger door one. All Jags has the same feature. Sorry if I didn't explain well.
Old 10-04-2012, 01:02 PM
Thanks, that's sounds like a good plan to me... I will check that door over the weekend and I will keep you updated.
Old 10-04-2012, 03:31 PM
disguay's Avatar
Bitz31
emaraszek, I had this EXACT same problem. It drove me up the wall for about 3 months cause I had never seen this and I went through a couple door actuators to find the problem. The thing is that someone had stuck a multi-meter in the female part of the plug to test for continuity, however, this damaged the leads on the female part of the plug. I took one strand of copper wire, made a "booster" that extended the leads of the female part of the plug. Essentially, I separated a copper wire into strands, took one strand, and put it all the way to the bottom of the damaged connector and then bent it over on top so it wouldn't move. I connected it and it has been working ever since! The thing I can assure you is that you have a damaged wire/connector on one of the sockets for your actuator.
Hope that helps! I wish I took pictures
__________________
The Following User Says Thank You to disguay For This Useful Post:
Old 10-04-2012, 05:03 PM
I agree with you, cz if the actuator were broken most likely it wouldn't send a signal to the other ones when I lock it manually. The fact is that this actuator is not responding when required.
Tags
2002, car, door, fob, front, jagquar, jaguar, key, lock, locking, locks, open, toyota, types, unlocking, ur, xtype
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Copyright © 2010 Internet Brands, Inc. All rights reserved.
Powered by vBulletin® Version 3.8.7 AC1
Copyright ©2000 - 2015 vBulletin Solutions, Inc. All rights reserved.
JAGUAR and its logo are the registered trademarks of Jaguar Cars Limited. Jaguar Cars Limited is not affiliated with JaguarForums.com.
