Frunt subframe Bolt
Old 03-25-2015, 08:06 PM
rcssnowman's Avatar
Default Frunt subframe Bolt
Hi all. Has anyone had trouble with the bolts not coming out when removing the front sub-frame. I am trying to change the cat. on my 2003 x-type. I have printed off the how to PDF for this. The rear mount retaining bolt on the passenger side will not come out. All it does is turn. I have looked inside the frame and can see the nut part turning with the bolt. Is there a way to fix this?
Thanks RCSSNOWMAN
Old 03-27-2015, 05:36 AM
jagandfordnut's Avatar
Have a look at this from the British x type forum. It will show you how to get around it.
Suspension overhaul nightmare
Or if you do not want to do it that way here is another possibility.
https://www.jaguarforums.com/forum/x...e-free-113243/
Old 03-29-2015, 09:27 AM
Paulc732's Avatar
I can send you the wrench Dimensions if you want to make your own Very simple to do.
Old 03-30-2015, 07:34 AM
rcssnowman's Avatar
Thanks for the tip. It did help. All is good.
04Xjrsteve
05-07-2019 04:06 PM
Johnken
04-08-2018 10:21 AM
Johncy2000
10-02-2015 01:05 AM
baskervillema
10-01-2015 06:43 PM
Quick Reply: Frunt subframe Bolt
