Gearbox fault
Old 10-02-2011, 11:18 PM
Carwatcher's Avatar
Check your battery...a low/bad battery will cause this.
Old 03-29-2015, 01:38 PM
juggernaut's Avatar
Gearbox fault sometimes puts your car in Limp mode, and hence the hesitation in acceleration. The gearbox may be fine, but an electrical issue such as a short maybe causing it. I had a Gearbox Fault message together with headlight and cruise control failure, and of course resulting in limp mode. It was an electrical issue caused by a corroded alarm sounder battery (behind front left wheel). After disconnecting the sounder and replacing the blown fuse (which also to be for the control cruise control and headlights circuits) all was well again. The fuse number is different on different build years of the Jaguar X-type. The following link was useful: GEARBOX FAULT , CRUISE CONTROL NOT WORKING,
JaguarLover101
48
06-12-2023 10:28 AM
3lvis
10-01-2015 01:56 PM
dmatthewman
09-30-2015 10:10 AM
jjmiah217
09-28-2015 09:09 AM
Quick Reply: Gearbox fault
