Hazy headlight remedy!
Richxtype2ds (10-08-2019)
Hazy headlight permanent fix
After wet (water and mild dish soap) sanding very lightly with 1000 grit sand paper, clean thoughly, use Krylon Fusion for Plastic top coating, non yellowing, UV protection. Use very light coats several times, assuring it is dryed between coats. The initial coat will show slight "orange peeling" don't fret it blends out as you progress.
This is a permanent solution. I have never had to repeat it, but hey, if I do, pretty inexpensive for around $8 U.S., and I've done 3-4 cars per can.
#28
Fletch44
09-28-2015 02:21 PM
