X type wagon 2005 cooling fan keeps on running
Old 11-17-2018, 09:01 AM
frujag's Avatar
Default X type wagon 2005 cooling fan keeps on running
Hello,
Have Jag x wagon 2005. Fan keeps running when I turn off motor. Why?
Anyone else with problem.
Can it be wiring or reistance induced problem
thanks
Old 11-17-2018, 09:08 AM
Received 2,577 Likes on 1,783 Posts
Is the coolant level correct? Has any recent work been done that required draining and refilling the cooling system? If so, the system may have trapped air and must be bled correctly.
Most likely a failing or sticking thermostat. JLR part number is C2S11278.
Old 11-20-2018, 03:40 PM
frujag's Avatar
thanks,
we will check coolant, thermostat and if this fails look at the relays.
any other sources or other models with similar problem?
Old 11-20-2018, 05:41 PM
DUNKS's Avatar
Default FAN
HI. I had this problem and it turned out to be a faulty engine temp sensor.
Old 11-21-2018, 12:44 PM
Dell Gailey's Avatar
1. Air trapped (needs to be burped)
2. Low coolant
3. Thermostat
4. Coolant system temperature sensor
5. Fan control module
KingHlayi
12-19-2017 12:00 PM
GrahamPhotog
11-10-2015 01:29 AM
bsprowls
01-20-2012 09:26 PM
gerwitz
07-01-2010 12:02 AM
goaliesdad
01-28-2009 08:24 PM
Quick Reply: X type wagon 2005 cooling fan keeps on running
