Cold in my jag!!!
Cold in my jag!!!
Well I am not sure about this one but I am getting air from somewhere in the footwell of my 2003 X type. It is chilling with the temps dropping!! I am not sure if this happening in the summer or it had happened last year but it is an issue now... Well here is what I know!!The heat is working and is coming out of the vent under the dash quite nicely. But the faster I drive the more cold air is coming around my feet. It is mostly my left foot the one nearest the door. Any ideas do I have a grommet a seal or something around that area that may be the issue???
Any help would be appreciated!!!!
THANKS
THANKS
Received 3,824 Likes
Striker, your easiest way of figuring this out will be to pull the wheel well liner out of the left front wheel and then look at the grommets there. It is very possible one of them has gotten moved or the boot may have gotten ripped and is now letting air in. Hard to say at this point. But, you have a few boots down in that area. I would be looking specifically at the boot around the steering column. Based on the amount of air that you are talking about, that will be your biggest offender.
VinnyT
69
05-17-2021 09:30 AM
