Ignition key stuck
Old 04-15-2014, 07:48 AM
jyasment's Avatar
Default Ignition key stuck
I have a 2004 X Type and have a stuck ignition key. I need to remove the cylinder lock for replacement but am unable to depress the "lock indent" for removal. The key appears to be stuck in the position 1 which is where it is supposed to be for removal yet I still can not depress the "lock indent". How can I get te cylinder out at this point?
Old 04-15-2014, 09:11 AM
GGG is online now
Received 16,764 Likes on 12,153 Posts
Welcome to the forum jyasment,
I've copied your question from New Member Area - Intro a MUST to X-Type forum.
This is definitely one for the model specialists and members here with the same model will be best able to help.
Old 04-15-2014, 09:34 AM
Stuart Beattie's Avatar
Hi Jyasment,
The ignition may be clinging to the key if your gearbox is still sensing it is in "DRIVE".
Have you looked at the parkbrake or the J-Gate, it may be that the gear selector is just off, maybe a wiggle will help?
I have heard of this post which may help, I am thinking something is loose or "in the wrong place", but I am guessing, hope this helps?
https://www.jaguarforums.com/forum/s...esolved-93076/
My personal theory is something unwanted has fallen into or down in the J-Gate area like an odd key or some item (chewing gum wrapper or parking ticket??)that may be obstructing the gears, handbrake or park mode and it is therefore blocking a signal to disengage the electric signal?
GOOD LUCK! Regards, Stu
Last edited by Stuart Beattie; 04-15-2014 at 09:35 AM. Reason: spwerlling, sorry :)
jyasment (04-19-2014)
Old 04-19-2014, 11:54 AM
jyasment's Avatar
Talking Success
I was able to get the cylinder lock out after i removed the solenoid on the left side of steering column which interacts with the cylinder lock. I could then wiggle the stab and get the cylinder to spin to the correct position to allow me to depress the detent and remove the cylinder. YEA... now I can purchase a new cylinder lock & key for replacement.
Thanks to Stuart for his input which did help me move forward.
Stuart Beattie (04-19-2014)
dsnyder586
04-04-2019 02:38 PM
XJsc-guy
11-23-2015 01:56 PM
1964Daimler
10-03-2015 12:18 PM
RaceDiagnostics
09-13-2015 02:22 AM
Clamdigger
09-12-2015 03:43 PM
Quick Reply: Ignition key stuck
