Instrument cluster goes nuts after some driving
Hi everyone,
I'm glad to join this community of great car drivers, but unfortunately the occasion is not of joy. My car developed out of nowhere a turning on and off instrument panel problem, gauges going down and back up, all warning lights on / off, security red light next to gear shift blinks, power steering goes on / off, AC (climate control) will go on and off and later on show a communication error message. All this while driving for 20-30 mins and would stop if the car rest for some time in some cool place (problem comes faster if it's really hot outside).
Some details:
Model: Jaguar X-Type 2003, 2.5 Sport
DTC: P1638
What I did so far:
1.) New Battery - Varta 80ah
2.) Replaced all fuses related to alternator, instrument cluster
3.) Checked charge, after initial 15V when car starts it goes down to about 13.3v with head lights on.
4.) swapped R7 ECU relay with a similiar one.
5.) tried to play with the wires under the steering wheel but couldn't reproduce the problem.
6.) Cleaned and tightened all ground wires in engine bay.
7.) Added very thick power cables for +/- and all ground points in engine bay.
Please, before I go and send the cluster for diagnosis, provide me with some tips, maybe you have encountered the problem too?
Thanks in advance and greetings from Yerevan!
David
Some details:
DTC: P1638
What I did so far:
David
Received 3,823 Likes
ArmXT, first off, welcome to the Forums. Lots of good information and people here. So, sit back, enjoy, learn what you can. But, please stop by the New Member Section and introduce yourself. We pride ourselves in being a better car group and as you will find, we like to get to know one another.
As for your problem, are all the lights going out on you along with the gauges falling to their OFF state? If so, you may simply have a broken solder joint on the backside of the instrument cluster which is causing the power to the instrument cluster to be interupted. Something you might want to try is starting the car and then giving the dash a good thump with your hand to see if you can cause the instrument cluster to fail. If you can make it do that, then this is pretty much confirming you have a bad solder joint. If only some of the instrument cluster is acting funny, then you are most likely looking at a communications issue and that can be interesting to figure out due to the networking inside the car.
As for the fix for a broken solder joint, you can remove the instrument cluster and look at the solder joints to see if you spot any with a black ring in the solder joint. The blackness is the crack. A little bit of time with a soldering iron may be all that you need to get your instrument cluster back to 100%. Just make sure not to be overly zelous with the solder as you can also create tons of problems if you get things shorted together. Otherwise, you may want to consider finding an electronics shop that will do the soldering for you.
ArmXT (07-07-2014)
Thank you for the assistance guys.
I have tried to re-connect the instrument cluster two plugs but nothing changed, will try to do so for the ECU. Is it in my foot-well btw? The one in the engine bay I think is the TCU. It's automatic, indeed.
I also tried hitting it from the top of the dashboard or from the sides, didn't bring the problem back, just after some driving of 30 min approx it will appear.
Arm, the ECU is under the cowl on the right side of the car (ie, if you open the hood/bonnet of your car, it will be in the far left corner of the engine bay if you are standing at the front bumper). The TCM is under the dash of the car.
I wish you luck in trying to figure out where the source of the problem is.
ArmXT (07-08-2014)
Hi again,
I cleaned today the ECU connector but nothing changed unfortunately, still it's disco time after driving for a while.
Anything else I should try before ordering an instrument cluster?
I'm having a hard time finding same serial numbered cluster on Ebay. Can I use something that has a different end letters to it? mine is 1X4F-10849-AL and the rest which are available come with BL / EL, etc. Any issues fitting one of those? I would take it to a Jag pro for re-programming anyway.
ArmXT- I'm having the same issue. I replaced the battery 2 months ago when I initially had the code (and a no-start problem) and it has been fine until now. Now when my wife drives the car the dash lights up and the odo goes blank and once restarted it's ok but stores the P1638 code. Car drives fine but there is obviously an issue. What did you do to resolve the problem?
Thanks ArmXT. The more I read this thread and others on the subject I think I may have a slightly different problem. My wife has been the only one in the car when the fault occurs and she said all the warning lights would flash, the odo would blink, and the ACC panel acted up. She also said it occured when hitting a bump in the road one time. After it occurs everything goes back to normal with the exception of the CEL. No other drivability issues. It happens every couple days. Maybe a loose ground?
In case this helps someone, I had the same exact issue. It turned out to be two of my coils were shorting out or 'backfiring' as the mechanic put it which was putting a ton of voltage through the computer. It actually fried my transmission computer and I am now stuck with an endlessly blinking transmission light.
al_roethlisberger
09-11-2015 10:04 PM
