Go Back   Jaguar Forums - Jaguar Enthusiasts Forum > Jaguar Models ( Modern ) > X-Type
Sign in using an external account
Register Forgot Password?
Search
X-Type 2001 - 2009
Welcome to Jaguar Forums!
Welcome to JaguarForums.com.
You are currently viewing our forums as a guest, which gives you limited access to view most discussions and access our other features. By joining our community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join the Jaguar Forums community today!
LinkBack Thread Tools Search this Thread
Old 12-15-2008, 12:59 PM
fclombino
Guest
Posts: n/a
Default Intake Manifold bolt torque?
Does anyone know the intake manifold bolt torque for a 2004 X type 3.0L.
I am changing my spark plugs and low and behold you have to remove the intake manifold to get to the 3 rear plugs.
Old 12-15-2008, 01:49 PM
ud
Default RE: Intake Manifold bolt torque?
According to the JTIS manual..All the intake manifold Bolts are tighened to 10 Nm or 88.5inch poundsor 7.375 foot pounds...I'd use some gasket sealer with the new gaskets and tighten to 90 inch pounds and call it a day.
Click the image to open in full size.
Old 12-15-2008, 02:44 PM
fclombino
Guest
Posts: n/a
Thanks Dennis! Thats some good info. I Appreciate it.
Old 12-15-2008, 07:40 PM
310jag's Avatar
Send a message via AIM to 310jag
I just did my upper/lower manifold gaskets and spark plugs about two month ago. Fortunately it's not that big of a job, but the all of the necessary gaskets run about $150. Do NOT use any sealer on them. They are meant to go on dry.
You will want to replace the upper manifold gaskets (6) lower manifold/fuel injection manifold gaskets (6), and the throttle body gasket. And while you have the upper intake manifold off of the car, it's a good idea to replace the two intake manifold tuning valve gaskets as they tend to go bad fairly often. Not to mention it's much easier to remove the lower valve if the manifold is off of the car.
__________________
Sales Guide, Jaguar / Land Rover of Louisville
Area 51 Jaguar Drivers Club
Sable 75 XJ6L, Masons Black 84 XJ6 Sov., Curlew Brown Metallic 86 XJ6, Cobalt Blue Metallic 86 XJ6, White Onyx 05 XJ8L
Old 12-15-2008, 08:39 PM
bojangles
Guest
Posts: n/a
I actually disagree... the gaskets are fully reuseable. some people prefer peace of mind to have new ones but the silicone gaskets are no problem to use again. I have had mine apart a few times and never changed them, they seal perfectly well. For sure you need to clean everything spotlessly and surgically clean.
Old 12-15-2008, 10:32 PM
310jag's Avatar
How many miles are on the car in question? Of course they can be reused, up to a point. If the car has enough miles on it to justify a spark plug change it's probably time to replace the gaskets.
__________________
Old 12-15-2008, 10:55 PM
keitho64's Avatar
In the JTIS manual it states to drain the coolant. Is that necessary? Are there coolant passages in the upper plenum? I do believe the manual but am just curious from someone who has been there.
__________________
Keith
2004 X-Type 3.0 Sport
1969 Porsche 911T
1964 Chevrolet Corvair
"Life is too short to drive a boring car!"
Old 12-15-2008, 11:34 PM
bojangles
Guest
Posts: n/a
keith, no need to drain coolant. ...
310jag, my car has 205,500km on it.
Old 12-16-2008, 07:49 PM
310jag's Avatar
keith - Draining the coolant is not necessary. You will have to remove two or three vacuum lines from the manifold, remove the 4 bolts holding the throttle body to the upper intake (the tb will stay in the car, and kind of just float there), loosen a couple of screws on the rear of the manifold in order to seperate it from the wiring harness that runs behind it, remove a small support bracket on the rear of the manifold and one on the left hand side under the throttle body. After that, remove the (6?) bolts (I can't remember how many) that hold the upper intake manifold down, then you can get to the lower fuel injection manifold. Remove the black plastic cap that covers the schraeder valve on the fuel rail. Covering it with a rag, press the valve to release the fuel pressure in the system. Not much fuel will come out, but enough to justiy covering it with a rag. Then, follow the fuel line which will run behind the engine to the right hand side of the firewall. Disconnect it at the quick-connect coupler, again, covering it with a rag when you do so. There are also a couple of wiring harnesses that connect to the lower manifold that need to be disconnected. You'll see them, they're pretty obvious.
Now the lower manifold will lift off of the block, after snaking it around a bit. Be very, VERY careful from this point on. You will be looking down at 6 oval holes in the top of the block that go directly into the engine. If you drop anything down in there, you're screwed. It's a good idea to cover these holes with some cardboard/tape until you're done.
Pull the old gaskets out of the top and bottom of the lower manifold and replace them. Use a razor blade to clean the surface of the engine to which they mount. Refit the lower manifold making sure to reconnect the wiring/fuel line, and bolt it in place. Then the upper manifold can go back on.
It all sounds a little intimidating, but you'll be surprised how un-intimidating the engine looks without the intake manifold on. Let me know if you have any questions. I'd be glad to talk you through it if you have any other questions.
__________________
The Following User Says Thank You to 310jag For This Useful Post:
12yrold (10-13-2012)
Old 12-16-2008, 09:37 PM
ud
Nice write up there 310..very handy reference.
Old 12-16-2008, 11:57 PM
keitho64's Avatar
Thank you for all the excellent info. It sounds very straight forward. I had to swap the intake manifold in my sons Oldsmobile with the 3.8. It sounds very similar. I doubt I will be doing this job before spring but I will definitely ask if I have any questions.
Thanks again, I sure am glad I found this forum, this is a lot of useful information and willing participants.
__________________
Keith
1969 Porsche 911T
Old 05-30-2009, 06:15 PM
Hey,
where in JTIS Software is written "how to remove the intake manifold"? I search for this but whithout result.
Thanks, Patryk
Old 06-01-2009, 09:30 AM
keitho64's Avatar
Patryk
On mine I selected Service for the X-Type 2003
Next I clicked on the 'Powertrain' icon (picture of engine lower left corner)
Next 'Engine' icon in the upper right corner
Next 'In Car Repair' which is upper right center icon
This brings you to a list of services and the top one in Intake Manifold 30.15.01
Let me know if this helps.
__________________
Keith
1969 Porsche 911T
The Following User Says Thank You to keitho64 For This Useful Post:
zigzewel (12-30-2013)
Tags
30l, bolts, gasket, hpow, inlet, intake, jaguar, manifold, remove, removing, sealer, torq, torque, type, xj8, xtype
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Copyright © 2010 Internet Brands, Inc. All rights reserved.
Powered by vBulletin® Version 3.8.7 AC1
Copyright ©2000 - 2015 vBulletin Solutions, Inc. All rights reserved.
JAGUAR and its logo are the registered trademarks of Jaguar Cars Limited. Jaguar Cars Limited is not affiliated with JaguarForums.com.
