jaguar x type 2.0 goes into limp mode bang steering wheel dash lights go out
Old 12-22-2014, 11:55 AM
davefowler's Avatar
Default jaguar x type 2.0 goes into limp mode bang steering wheel dash lights go out
bought a jag x type today to break but it to good to break the only fault is when you drive turn a corner the heater-plug light comes on then the dash gauges drop bang or apply some pressure to the steering wheel and the dash gauges come back on turn the ignition on then back on its fine just wondered if any one else has had the same / similar problem cheers
Old 12-22-2014, 09:27 PM
Thermo's Avatar
Received 3,822 Likes on 3,142 Posts
Dave, It is sounding like you have a wire rubbing inside the steering column, leading to the instrument cluster going thru a boot sequence.
Old 12-23-2014, 02:06 AM
davefowler's Avatar
Cheers gonna strip it down have a good look over Xmas . Is there anything to look out for other than disconet battery before unplugging anything .
Old 12-23-2014, 09:45 AM
Thermo's Avatar
After disconnecting the airbag, set it off to the side away from anything that can be tossed. While it is not likely to release once removed, better to be safe than sorry.
BrentGardner
24
01-18-2021 10:50 PM
Isoruku
06-19-2020 12:54 PM
Steve Langridge
09-03-2015 07:35 PM
SkinnyLard
08-30-2015 07:26 PM
J-Rock
08-25-2015 08:33 PM
Quick Reply: jaguar x type 2.0 goes into limp mode bang steering wheel dash lights go out
