Jaguar x-type fueal injector and fuel rail change
Hi Guys
I recently had my Fuel Injector and Fuel Rail changed. I have attached images you might find helpful.
Whoever does the changes I have done make sure of one thing that the bolts should not be tightened beyond 10nm. Its not a very difficult job if you have a little skill. All you need is good weather and a weekend. You can save lots of money.
ThankYOU
ThankYOU
first of all im so sorry for not replying i have just logged in after so long
if you are puting the same jaguar part replacement you do not need to reprogramme because the ECU already has been programmed for this part.
hope that helps
sorry once again
Resurrecting this one. Dumb question, maybe not dumb, but seems dumb.... Is the fuel rail under pressure, or is there anything I have to do about fuel pressure if I replace the injectors? I'm having to dig in to the top end to replace a knock sensor and though I'd replace the injectors while I was in there. Feedback is always appreciated!
ugotmale (02-14-2021)
Innovative Detailing
Detailing / Car care
01-20-2010 03:38 AM
