key fob just died
Old 12-26-2011, 10:03 AM
MosDefXType's Avatar
Default key fob just died
Guys my key fob died, i thought the battery was dead. replaced it with a new one, but no change. can i buy a fob and program it myself or i have to go to the dealer?
Old 12-26-2011, 01:50 PM
brucelee's Avatar
Do a search. You can program this yourself I believe.
Old 12-26-2011, 03:21 PM
tzhyang's Avatar
It happens to me too recently, I dont know if its the temperature drop to be blamed. I reprogrammed it and it work again. All u need to do is to slot in the key, turn to aux for 3 times and you should hear a chime, then press any buttons on the remote. Usually after the programming, I will crank my engine and then turn off only it would work. If you buy new key, you will still need to program the remote, as for key, jaguar cut it for free, but I reckon will u need to pay to program the key (metal-not remote), if not you will be only able to unlock/lock your doors but not able to start your car, which cost roughly about $50. Hope it helps.
Old 12-27-2011, 12:44 PM
thanks, i will try to reset it.
Old 12-27-2011, 08:30 PM
Received 7,878 Likes on 4,762 Posts
Here is the info again
bob gauff
Old 12-27-2011, 11:35 PM
ok guys i managed to reset my fob.
1 got into the car closed all doors.
2 switched the key between I an II 4 times
3 heard a sound
4 pressed a button on my fob, heard another sound.
5 fob is working.
thanks
Old 12-28-2011, 09:23 AM
reyesl's Avatar
Wow
I gave away $65 to a Jaguar repair shop 2 hrs away (plus cost of fuel and lunch) when I could have done it myself within 1 minute?
Thanks for the info
redxk8
09-30-2015 08:18 AM
Listers
09-30-2015 07:45 AM
oldjaglover
09-29-2015 03:27 PM
Jzar
09-27-2015 02:55 PM
Quick Reply: key fob just died
