Leak coming from top of intake (Picture)
I have a loud hissing noise coming from the side of the upper intake on my 2002 X with the 3.0 motor. I was hoping someone could tell me if this is normal, or do I need to have it checked out. I attached a picture and circled the area that is leaking in red.
Any help would be greatly appreciated!
Thanks!
Jon
Thanks!
Jon
Received 3,825 Likes
Jon, if you go to the auto parts store, you can get new O-rings for that part. They are like $15 each, but replacing them is really easy. You can undo the 2 bolts, pull out the old o-ring and then slide the new one one. Pretty easy job. These o-rings are known for failing, so, you are not the only one that is suffering from this. Should do the one under the one that you are worried about. Normally once one goes, the other isn't far behind.
Thanks!
Jon
Thanks for the info! I had an o-ring in the garage that was the same size. I just swapped it out. As far as the lower, I couldn't see any ways to swap it out without taking off the upper intake and I don't plan to ever do that again if I can help it. I just move the o-ring around and greased it.
No more whistling noise!
Thanks guys!
Jon
Thanks guys!
Jon
Thanks guys!
Jon
Thanks guys!
Jon
That is really no problem to stretch it?
I honestly couldn't figure out how you were stretching it around the lower tuning valve. I just loosened 3 or 4 of the upper intake bolts closest to the tuning valve and lifted the upper intake up enough to remove the valve. Then I just swapped the o-ring.
Jon
Jon
BrentGardner
26
04-17-2024 05:19 PM
xjrjag
10-27-2021 11:48 PM
Ophitoxaemia
09-14-2015 02:40 PM
FS[Central US]: 1999 XJ8 Parts or project car for sale Lawrence, KS
casepie
08-30-2015 09:49 PM
