Limp mode, no reverse lights or park aid, j gate selection not red
Old 01-22-2015, 07:54 PM
Ron42's Avatar
Default Limp mode, no reverse lights or park aid, j gate selection not red
Just bought this Jaguar 2.5 auto, car drove fine the day before but the next morning I started it up and got the gear box fault/ no cruise message code p1634 or 43 low circuit fuel pump is what the local Penz shop scanned.
All fuses good, swapped relays 15, 17 and R3, R8. TCM looked good. I've already changed intakes and (water pump too) I did get a catalytic converter code with that scan.
2002 X-Type 2.5 auto
Old 01-23-2015, 02:52 AM
GGG is offline
Received 16,798 Likes on 12,167 Posts
Welcome to the forum Ron42,
I've moved your question from Intro to X-Type forum. Members here with the same model will be able to help.
Old 01-26-2015, 02:53 PM
Paulc732's Avatar
This may sound funny but get your battery load tested.
Our cars can throw some strange codes when the battery goes weak.
I had an intermittent gearbox fault and the "s" button by the shifter would not work on mine. could not track it down.
as soon as I put in a new battery all was fine.
Ron42 (01-27-2015)
Old 02-10-2015, 12:56 AM
Kane973's Avatar
Did you fix the problem
Old 02-10-2015, 12:57 AM
Kane973's Avatar
Did you fix it
Old 04-05-2016, 10:21 PM
El Nio's Avatar
Originally Posted by Kane973
Did you fix it
Im have the same problem. Can anyone help
D.K
12-10-2023 02:05 AM
Forcedair1
05-14-2023 03:28 PM
afterburner1
12-16-2015 12:12 AM
tberg
09-07-2015 07:32 AM
MC36
US Lower Atlantic
09-01-2015 07:34 PM
Quick Reply: Limp mode, no reverse lights or park aid, j gate selection not red
