x type 2002 broken dispstick handle
Old 03-15-2024, 09:08 PM
mickvic's Avatar
Default x type 2002 broken dispstick handle
Broke the handle off my dip stick , engine oil. Does the dip stick tube come out of the engine block? Any other ideas to get it out and replace?
Old 03-16-2024, 05:57 AM
Peter_of_Australia's Avatar
The dip stick is make from a ferrous material (I just went out to my X-Type and double checked). Hence, the obvious solution for you would be to use a magnet on a stick (those are available for purchase (cheap), with an extendable stick (like an antenna)) to pull the stick out with that magnet.
PS: ...if you cannot get it with small pliers or tweezers...
mickvic (03-18-2024)
Old 03-23-2024, 01:34 PM
dh53's Avatar
Part number for dipstick is C2S20878. I haven't tried it but it looks like you remove 1 bolt on the dipstick tube mount then simply pull and twist the tube off. Just an O-ring sealed slip fit into the engine.
https://www.sngbarratt.com/English(U...9-72c268025dda
mickvic (03-24-2024)
Old 03-24-2024, 05:23 AM
mickvic's Avatar
Thanks a lot yeah the magnet doesnt work
Old 03-24-2024, 10:47 AM
Dell Gailey's Avatar
Undo 8 and pull out 7.
Iticip
08-02-2022 07:44 AM
tinumon
10-26-2017 02:52 AM
Simplemechanic
11-09-2014 12:24 PM
PanamaJag
07-27-2014 01:57 PM
Quick Reply: x type 2002 broken dispstick handle
