No Front parking lights...?
Hi all,
I have a 04 XType AWD 3.0L With no front parking (running) lights. The hazard and turn lights function normal as do the rear, head and fog. The fuses are fine. Any leads would be greatly appreciated, as I would prefer not to give Indiana's Finest any more reason to pull me over other than to admire my Jag!
Received 3,825 Likes
Scotch, to get what you are describing, I can only think of 2 possibilities. Please keep in mind that I am assuming you are talking about all 4 of the front running lights not working (ie, 2 in the headlight high beam lens, the 2 on the side of the car on the bumper).
The more likely situation would be that you simply have all 4 bulb blow at roughly the same time. This can be easily proven by getting some new bulbs and replacing the ones in the side marker lights. If the new bulbs light up, then that would confirm this problem. Now, for the other possibility.
The other option is that the plug on the back of the fuse box got unplugged. Not unheard of, but unless you have been in doing wiring changes in the fuse box, the likelihood of this happening is pretty low. But, you can remove the engine bay fuse box and flip it over. If you think of the fuse box as having an up and a down, the upper part of the fuse box is going to have 3 plugs across the top in a little bit of a V pattern. The bottom of the fuse box has no plugs. In the center of the box, you will find 2 plug near the edges. You are after the left side connector. Make sure that is tight and installed fully. May want to even take it off just to do a visual of the pins to make sure that they are not rusted or anything else. The other thing that makes me think this is not the problem as you should be experiencing a few other pieces to the car not having power and therefore seeming like a bigger issue than just the running lights being out.
Hope this gets you back on the road in 100%.
Scotchtravelers (04-13-2014)
Thanks again Thermo, It was a multi light blow out on the side markers. They are all working. However the front 2 (1's next to headlights) still do not work. I replaced the bulb on the right just because it was easier than the left, but it still does not light when running lights are on. The turn and emergency work fine. The wiring and connectors look good. I am looking into the wiring schematics, but have found nothing that separates these lights from the side markers.
Rlover
03-30-2016 10:04 PM
neruda
10-18-2015 01:19 PM
MC36
US Lower Atlantic
09-01-2015 07:34 PM
