O2 sensor wiring diagram ??
Would anyone happen to know or can show what the wiring for the downstream o2 sensor is ? I think it's the following , but not certain -
O2 Sensor - O2 Connector Socket in engine bay
Black - Blue = Heater
Black - White with Green stripe = Heater
Blue - Brownish green color = Signal
White - White = Ground
Received 3,823 Likes
excursion, looking at the diagrams, this is what I am seeing as far as what the vehicle side of the wiring is (doesn't list what the sensor side is as that can vary from manufacture to manufacturer): Please note that the items in the parenthesis are for bank 2 and those outside are either for Bank 1 only or apply to both banks.
Pin 1: Blue (Blue with yellow stripe): heater ground
Pin 2: White-Green (White-red): Heater power
Pin 3: White: lamda sensor ground
Pin 4: Brown: Signal wire
myexcursion (11-23-2014)
Cris, not to question what you bought, but from our experience on the forums here, if you have O2 sensors with no pre-fabricated plugs on the end, you are going to most likely have tons of issues. Yes, they are cheaper than the others, but for some reason, they just don't work so well inside of our Jags. Can you make them work, you might get lucky. But, I think you are going to find that spending a few extra dollars is going to be well worth a lot of your time.
Wiring Colour codes. To the 4 o2 senors. Please.
for bank 1. o2. Up stream.. Ad bank 1. o2 down stream. Senors.
Wiring codes.
For bank 2. o2. up stream. Ad bank2. o2. down stream senors.
car5car
01-29-2016 11:29 AM
