is this the Outlet pipe connection?
searching but found nothing so far..............the pipe has 3 hoses connecting to it.....upper rad. hose, coolant tank and what looks to be a heater hose.....
the pipe tree is in great shape, but found this "what i hope to be" the last leaking issue to deal with as i have replaced all the cooling systen components.
i would like to know if the rubber seal is an "o-ring" or another special ring, and where i can find it.
thx
-mike
thx
-mike
hi tford,
sorry not to answer til now.......been gone all week.
i bought the O-ring at the jag dealer here in town......3 bucks.
part number C2S22458
it is online too, but who wants to pay for shipping.......
C2S22458 Jaguar O-RING
dwclapp, could this o-ring cause an intermittent coolant leak down that end of the engine that drips onto the Bank 2 exhaust pipe? I'm chasing slight coolant loss and recently noticed a small amount on garage floor below that section of the engine. I took off the right front wheel and access plate for serpentine belt tensioner, then ran engine. Couldn't see anything leaking, but this hose/pipe junction is suspect. Thanks for the pictures.
swing: This coolant leak is difficult to find, but easy to fix. So the "lazy man's" remedy is replace this suspect o-ring, hope your leak stops, and if it doesn't, replace the next easiest, suspect part.
The o-ring I replaced cost only $2 at a hardware store, or $7 for the official Jaguar part C2S22458 on eBay, and takes only ~30 minutes to replace if you're cautious the first time, ~10 minutes with experience.
So my 2 cents: replace this suspect o-ring, declare victory if the leak stops, or keep searching if the leak continues. The coolant splitter housing (see pictures) has 2 more o-rings you might check, but I didn't replace those because other forum members point to problems with the suspect o-ring, and the leak stopped when I replaced it.
swing: The jpg's are from my iPhone while working on my 2002 X-Type.
The png's are screen grabs from this eBay post: 2007 Jaguar Xtype 3.0L Coolant Pipe Tube Sensor With Tee OEM (Part# 1X4E-8548EA) | eBay
Both picture formats are very common.
swingwing (11-13-2016)
clubairth1
22
12-19-2022 07:08 PM
aholbro1
08-05-2021 05:02 AM
xjrjag
09-27-2015 01:53 AM
