x-type 3.0L engine oil leak
Old 01-02-2011, 07:04 AM
Thermo's Avatar
Received 3,823 Likes on 3,142 Posts
Chris, no other recomendations. The leaking oil pan is a common problem with these cars and unfortunately, there is no easy way to fix it. Due to the location of a single bolt, it requires dropping a lot of stuff to access it, leading to the big cost. In short, the transfer case needs to be dropped from the car. There is an alternate method, but I personally am not a fan of it and I would be asking how the shop plans on doing the job. The alternator method involves drilling a hole in the bracket for the transfer case so you can access the bolt. When it comes to major driveline components and knowing the transfer case is weak to begin with, I like as much metal in those components as possible. Some have had this done and they say they don't have any issues. So, make your own decision.
Old 01-02-2011, 11:44 AM
chknhwk's Avatar
Thermo, my Jag is parked at this time because of the same oil leak. My question is this: once the gasket is replaced will this correct the problem permanently or will the same problem eventually crop up?
Old 01-02-2011, 02:58 PM
sport30's Avatar
Banned
the problem will come back...
Old 01-02-2011, 07:21 PM
Thermo's Avatar
chknhwk, unfortunately, there is not garantee that the problem will be permanently fixed. I'm sure if you toss in enough gaskets, sealant, etc, you can delay it, but oil has a way of finding all the holes you try to plug up.
chknhwk (01-03-2011)
Old 01-03-2011, 11:48 AM
MarkC's Avatar
What is the root cause of the oil pan leaks? Crappy gasket? Distorted sealing surface? Self-loosening bolts? Sorry, but I don't buy the argument that the leak will come back if the pan is properly sealed. Is there a service bulletin on this?
An anecdotal story: The GM 3800 engines of 1998 vintage experienced chronic oil pan leaks (at least on two cars that I owned). The root cause of these leaks was "ripples" at the corners of the oil pan sealing flange (the pan was stamped out of sheet-metal). The fix, per the factory TSB, was to apply a thicker bead of RTV gasket maker to each side of the windage tray / gasket and re-assemble. Material cost was only a few bucks for the RTV, but took about 5 hours labor. Bottom line is there was a cause and a solution.
Old 01-04-2011, 06:24 PM
sport30's Avatar
Banned
I aree that there should be a root cause. But according to my jag dealer tech friend, they all leak, and they all come back leaking. Jag has not figured out the root cause yet. I doubt they will at this stage. The aftermarket will not likely do this either, volumes are too low, and the service industry loves this kind of 1000 dollar gasket job.
I even have decades of aluminim casting of oil pans specifically. LOL.
Full RTV custom moulded seal seems to be the modern way instead of a metal/rubber gasket. This jag has the metal rubber thing.
I dropped my oil pan, cleaned everthing fanatically, and put a new gasket.
that was 8 months ago, and it is seeping again now. I suppose I could have put some extra silicone - I will do that if I take the job on again.
Old 02-04-2011, 05:41 PM
billodavio's Avatar
I drive an XJ myslef 2005, however it was leaking specially when it is parked for a long period. I don;'t know why but when i use it daily it just doesnt leak. My local mechanic told me the story of 'normal' leaking on jaguars which didn;'t make any sence at least it is not a 1970 model to accept the fact that the block is a US design (oldsmobile), but with the new models under BMW then Ford that is just not accepted. A local mechanic however solved the problem in 2 minutes and costed me 5 dollars and that is putting a special liquid in the engine that would seal the leak from the inside. That is only done if the leak is small. It has been 2 years now with no leaks whatsoever and I must have changed oil 5-6 times so far. I am sorry I don't have the name of that special liquid, it might be an STP product.
Old 02-07-2011, 05:28 PM
310jag's Avatar
You guys are nuts. The oil pan gasket is a five minute job.
...once the engine is out.
Torrid
02-15-2020 08:03 AM
X_Type_South_Africa
12-09-2015 05:37 PM
Thempsc
09-07-2015 02:29 AM
peterg19
08-28-2015 08:42 AM
dpappyp
08-27-2015 06:31 AM
Quick Reply: x-type 3.0L engine oil leak
