Stereo unlock codes, help!
Old 03-09-2010, 12:11 PM
MeeMo's Avatar
I'm glad i can help
Old 08-24-2012, 07:04 PM
Adamsrecovery's Avatar
Originally Posted by MeeMo
dude try this and till me what heppen
press (next + A MEM + PTY ) at the same time and the sterio will unlock
till me if it works
You are truly the master!!!!! Thanx.
Old 10-09-2012, 10:26 PM
MeeMo's Avatar
no problem im glad i can help
i used to work for Land Rover , Range Rover & Jaguar dealership and i know a lot about these cars
Old 10-10-2012, 03:04 AM
unclefish's Avatar
my dealer GAVE me the code. they didnt charge me.
Old 10-10-2012, 09:23 AM
GaryBentham's Avatar
Yeah,
I suffered a heart attack two years ago. While I was in hospital and then recovering my x-type (which had been serviced by the dealer three weeks before) battery totally died. I had to buy a new one. I replaced the battery to find the radio required a code. Easy, the code was in the manual when I bought the Jag, from a Jag dealer. When I tried the code did not work. So, go to the dealer because jaguar have a database where they store the codes. Got the code from Jaguar, did not work. Dealer said they could get the code by the radio serial number, just leave it with them for an hour. Did that, when I returned the radio was working again. Dealer charged me £100 for the service. Could have bought one and installed for less.
Old 11-01-2012, 11:09 PM
chopr's Avatar
I tried MeMo's unlock idea after changing the battery in my 2004 XK8. No luck. So, I decided, rather than pull the console etc, to try one of the online "Radio Code" services. Supplying them with my VIN and $24 hard earned dollars, they sent a code in about 2 days. It worked perfectly. No radio serial number needed after 1996, so states the site. Apparently, there is a data base for such things.
Old 11-01-2012, 11:23 PM
MarXJagX's Avatar
Thumbs up Hi I am new here
Just wanted to reply to this because in my dash I have what looks like a credit card... That is where the codes are... If you buy a used stereo I suggest u get the codes to it prior to buying it.. Just saying
Great to know there is a jag site also! Later!
  #28
Old 01-19-2013, 11:52 AM
MeeMo's Avatar
the thing i post works 100% on any x-type
and u will never need the factory code or to go to the dealership
Old 02-16-2013, 12:17 PM
JasonDG's Avatar
Smile Absolutely Fantastic....
Starter motor changed on my X Type, bad news.... Fly wheel is on its way out and then no radio as battery was disconnected - a bad weekend!!
but then
and it all works great
Thanks for the great fix!
Jas
  #30
Old 02-24-2013, 06:05 AM
flyrr100's Avatar
Silly question:
press (next + A MEM + PTY ), when you say next you mean >> right? And press them simultaneously or one at a time?
I have a replacement radio with a CD to replace my cassette. Just getting ready to install it.
Just a FYI, I had my battery disconnected for a while when I installed my ACM, and upon reconnection the radio worked right off the bat.
  #31
Old 06-12-2013, 12:08 PM
Jac's Avatar
Jac
Jac is offline
till me if it works
My battery went dead and I tried (next + A MEM+PTY) Not sure what (next) is so I pushed the right arrow button. Now the radio reads "Please Wait" and nothing works. Any idea what to do? I tried pulling the fuse and putting it back in but same thing. (Fixed) "Please Wait" means you have to let your radio on for at least 30 minutes before trying another code. (next + A MEM+PTY) worked fine.
  #32
Old 02-27-2015, 01:59 AM
pilatus's Avatar
Thumbs up
till me if it works
Thanks mate!
Worked like a charm on a '05 X-Type
  #33
Old 09-07-2019, 12:48 PM
Godwin's Avatar
Default Stereo code needed
[QUOTE=racerx82;5458]ok...good luck and plz let use know if you get that magic code....(ican use it myself)
thanks[/QUOTES] I need the code to unlock my stereo with VIN SAJAF62S82YC96134
Please help out.
St.Regis
04-06-2021 12:34 AM
2001 White XJ8
02-25-2021 05:02 PM
SeanU
09-18-2015 03:38 AM
Bigvettefreak
09-06-2015 04:27 PM
AL NZ
09-04-2015 08:39 PM
Quick Reply: Stereo unlock codes, help!
