Swap is Complete -- Lincoln LS Engine in My X-type Jag.
nice job
hey do you have a manual trans or auto? did you use the same injectors from your 2.5? could you contact me mushu1430@aol.com. I'm doing something similar to my x thanks
Removal
It's a big pain in the *** doing it that way, I did it that way. I had to remove it again. It's a lot easier going from the bottom.
#28
KS
Ive already sold this Jag....... it was a real easy swap! No computer changes. I used the original electronics and just swaped a few parts over from one engine to another....weekend job and no special tools but the engine lift.
Now you all know, dont say jag at the parts store say FORD..cheaper parts and its in stock.
I will check this post from time to time,if you have any Q's.
The following 3 users liked this post by willy-k:
#31
#33
#34
#35
Pondering something similar
Just bought an s type 3.0 with 182,000 miles. I believe I've blown the oil pan gasket in this past week and am not thrilled. In as much as the car has considerable mileage, I am entertaining the thought taking the opportunity to rebuild the engine. Could my s type 3.0 be rebuilt onto an ls block?
#36
I'm not surprised about the compatibility. I've tried to tell multiple people my 2000 s-type 3.0 has the same trans as a 2000 Lincoln LS 3.0. But because of the lack of cross-reference made available, people swapping Ford parts from Fords into their Jaguars with Ford drive-trains will be the narrow road. I barely started rebuilding my LS trans but I'm making my part swap too, however my swap is identicle. Good job and enjoy!
#37
you said you kept your old ecu on, i'm guessing that is the one off the 2.5? Your engine will not have full power because your ecu wont have the fuel settings the same as the 3.0 maps. I replaced my 2.5 with a 3.0 and kept the same ecu, but having a race with another 3.0 and lost quite drastically so i bought a 3.0 ecu, and now both cars kept next to each other down a 1 mile stretch of road! You'll see what i mean if you get the chance to race with another 3.0
#40
