Go Back   Jaguar Forums - Jaguar Enthusiasts Forum > Jaguar Models ( Modern ) > X-Type
Sign in using an external account
Register Forgot Password?
Search
X-Type 2001 - 2009
Welcome to Jaguar Forums!
Welcome to JaguarForums.com.
You are currently viewing our forums as a guest, which gives you limited access to view most discussions and access our other features. By joining our community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join the Jaguar Forums community today!
Tire Pressure Recs
LinkBack Thread Tools Search this Thread
Old 11-23-2008, 09:15 PM
Default Tire Pressure Recs
I have an 06 Sport with Proteus 18" wheels. Tires are Pirelli P Zero Nero 225/40/18.
Recommended pressure on the door jamb is 40 psi Front/35 psi Rear.
That's where I've got the tires now, but tech spec says tires can take as much as 51 psi.
Anyone had experience/results with different pressure settings?
Thanks...
__________________
2006 X-Type 3.0 Sport, Quartz, Premium Package, Bluetooth, ACM, DSC, 18" Proteus Wheels
Old 11-23-2008, 09:35 PM
Default RE: Tire Pressure Recs
what tech specs???
__________________
Old 11-23-2008, 09:55 PM
Pirelli's tech specs for the tires say max psi is 51. So they can definitely go higher than the "recommended" 40/35.
__________________
Old 11-23-2008, 11:33 PM
So what if the TIRE manufacturer says the tires can go to 51 PSI. You should listen to the CAR manufacturer as to the proper tire pressure to inflate them to.
If you use a higher pressure than what the car manufacturer recommends, 1) less of the tire tread will be on the road (aka they will be over-inflated.) 2) you will suffer a harsher ride (due to the higher pressure).
The tire manufacturer has no idea of the weight of the VEHICLE. That's what is the major determining factor in the correct tire pressure to use. They build their specs o that their tires can be used on a wide variety of vehicles (not all of which have the same weight nor load capacity.)
Old 11-24-2008, 04:59 AM
What you are reading on the tire is the MAX tire pressure. Meaning that the 51 is the MAX with a full load. not recommended you do that.
X-Type
Old 11-24-2008, 10:47 AM
ud
I run mine at 37 PSI on all four..Good ride, good tire wear.
Old 11-24-2008, 11:57 AM
The Chris X's Avatar
Stick with what's on the door jamb and only deviate a few psi depending on your comfort preference and the wear characteristics of the tires.
__________________
03 S Type R - Mafioso Intake+K&N, Akebono pads F&R
07 SAAB 9-3 turbo - BSR Intake/Downpipe, ECU tune, Powerstop rotors and pads
07 Jeep WK 4.7 2" BDS Lift, skids, bull bar, AT3's
06 Jeep XK Commander Limited 4.7 - K&N FIPK, Mopar Skids, Cooper AT3's - planning air suspension
Ex 2002 X Type owner
Member JCOP
Old 11-24-2008, 01:15 PM
whiteSTR's Avatar
If your going to the drag strip with stock radials, your optimum tire pressure is between 21-25psi in the rears and 35-45psi in the fronts.. You want the front tires high to reduce resistance, and the rears low to help shift the weight to the back tires..
__________________
White S-Type R (HRE 543s, Ported S/C, K&N, Custom Exhaust, EBC Red-Stuff, MB Quart Qs, Kicker L7s, Plans: ECU ReTune, 2.5 Pulley, De-Cat)
MTM Audi TT Quattro @ 27psi (adiós)
1973 Duster (Stage 3+ T76 Turbo, Street Legal)
Old 11-24-2008, 10:01 PM
My 2003 recommends 30/30. It's hard to believe they will recommend 40/35 - such big difference.
__________________
2005 S-Type 3.0
2001 Volvo XC-70
1989 Honda Pacific Coast 800
Old 11-25-2008, 10:52 AM
My 05 sport w/17s says 38 front 35 rear
__________________
2005 Black X-Type Sport
Old 11-25-2008, 11:21 AM
+1 w/ what some above have suggested. Run what the vehicles door jam label is suggesting unless you're doing a track session. Your vehicles suspension is tuned to specific tire pressures. Running too high of pressure will over-tax your suspension. Think of how much higher a basketball bounces when you continue to add air into it and how poorly it bounces when under inflated.
__________________
02 S TYPE SPORT 4.0
89 JEEP CHEROKEE 2 DOOR, 6.5" LIFT, 33" MTs
98 VOLVO S70 GLT
01 KAWASAKI ZX-12R NINJA
70 DODGE DART GT
Old 11-25-2008, 02:14 PM
Actually am getting hooked up with some Kumho Ecstas ASX this afternoon. My tread was very low and with winter coming I want good traction. My left rear tire was loosing pressure constantly, so it probably needed a patch. I think the continentals that were on it were original and I have 39K miles.
__________________
Old 11-25-2008, 02:21 PM
ud
You'll lovethat tire JJ..That's what I have..I run 37 PSI in them, FYI
Old 11-25-2008, 03:40 PM
Thanks Dennis, you running that pressure on all 4 tires???
__________________
Old 11-25-2008, 06:00 PM
ud
Yes..Ride is slightly firm, but tire wear is even..
Old 11-26-2008, 08:39 AM
I just installed my winter 16 inch rims and tires. Running 38psi up front, 35 in the back. After 3 seasons of experimenting, seems to be the right combo for my set-up. Seems that different tires like slightly different psi. If you stay somewhere in between the comfort and high speed settings all the way around, you should be good.
I was pleasantly suprised whenI pulled off my summer 17's (Hankook V4) that the treadwear was very even, none of that inside edge wear on the fronts that the X is known for. I chalk it up to having my alignment tech set the toe to as close to zero as possible.
__________________
Member JCOP
Old 11-26-2008, 11:04 AM
I've got to say, after my alignment and the new Kumho tires, my ride is quite a bit better.
__________________
Old 03-26-2009, 12:44 PM
Quote:
Hello all, long time lurker 2nd time poster (sorry I forgot to introduce myself the first time). I own a 2002 X-Type Sport 2.5L which I have had for just over 3 year's. I too just got a set of the Kumho ASX's in 225/45/17 for my Aguila's and I must say what a great tire for the price. Definitely wins best bang for your buck award.I previously had the Fierce UHP which were originally Goodyears attempt at a cheaper Z rated tire alternative to the F1 eagles. Kelly has since bought the rights and they are now called the EVO'Z's. Anyway the Z rated ASX's are by far a better tire. Low noise, great traction and just looks good. Big thanks to Dennis and the others for recommending this tire. Love em......
__________________
Ray
Old 03-26-2009, 01:38 PM
I don't have the user manual (X-Type 2005) with me because I'm at work, but if I recall correctly, it says 38 front 35 rear for 16 and 17 inch tires, and 40 front 35 rear for 18 inch tires.
__________________
2005 X-Type 3.0L
Old 03-26-2009, 02:43 PM
Yes Sevren the manual does say 38 front 35 rear for performance and 30 all around for comfort if using the oem conti's. It also says to add an additional 2 psi if using another type of tire other than than the conti's for the comfort setting. So basically 32 psi all around for comfort if using another brand of tire.
__________________
Ray
Tags
17, asx, cherokee, fierce, inch, jaguar, jeep, kumho, pressure, pressures, review, suggested, time, tire, tires, uhp, winter, xjr, xtype
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Copyright © 2010 Internet Brands, Inc. All rights reserved.
Powered by vBulletin® Version 3.8.7 AC1
Copyright ©2000 - 2015 vBulletin Solutions, Inc. All rights reserved.
JAGUAR and its logo are the registered trademarks of Jaguar Cars Limited. Jaguar Cars Limited is not affiliated with JaguarForums.com.
