Fuel gauge reading Half tank when full
Old 06-29-2013, 07:48 PM
Dr dome's Avatar
Question Fuel gauge reading Half tank when full
Hey Guys,
Has anyone ever had a full tank and the fuel gauge only says only half tank? I have filled my tank many times but the gauge stays at Half tank. Any ideas?
Thanks in advance,
The Dr.
Old 06-29-2013, 09:40 PM
Thermo's Avatar
Received 3,821 Likes on 3,142 Posts
Dr. Dome, from the sounds of things, you have a failed fuel level sensor. You have 2 sensors in your fuel tank and if one is stuck/failed to the empty condition, it will cause your fuel tank to read erroneously. You can get a feel for which one is failed by putting the instrument cluster into its diagnostic mode and in there, you will be able to scroll through and see if it is "fuel 1" or "Fuel 2" that is failed low. It reads out in a number between 0 and 255 and anything around about 20 is considered empty.
Dr dome (06-30-2013)
Old 06-29-2013, 09:47 PM
DPK's Avatar
DPK
DPK is offline
I can confirm Thermo's diagnosis..I had the same problem...Hope you have a warranty...I'm not saying that to be a dik, they have to drop the tank to get to the fuel pumps/level sensors..and that is pricey on labor.
Old 06-30-2013, 05:26 AM
Dr dome's Avatar
Well thanks Thermo and dpk. My only issue is my instrument cluster does not read like my other 3(meaning it just reads the trip and mileage. Do you know location of these sensors. Seeing that I have dropped the one in my parts car getting to it is not a problem... Finding the time to do it is. HAHA I have a shop with 2 lifts so jag dealer can kiss it. Could make it easy and just swap out the tank.
Old 06-30-2013, 05:34 AM
Dr dome's Avatar
Is it possible that I could swap out one of gauge clusters and put it in my car? Do I need to change out all the mods as well?
Thanks in advance,
The Dr.
Old 06-30-2013, 07:38 AM
Thermo's Avatar
Dr Dome, if you look at the top of the tank, you should see 2 rings about 6" in diameter. Under those rings is a complex of stuff (fuel pump, pickup, and level sensor). You spin off the ring, pull out the assembly and then put in a new one (assuming you know which side is bad) and you should be good to go. You can buy a new level sensor and it will snap right into the complex as everything from my experience on other vehicles is just clipped into place. If you have the lifts, then you are halfway there. when I did my truck, I had to drop the tank with the truck on the ground and use a jack to balance the 6 foot long fuel tank on. That was fun, NOT!!!!!
Sprayall
05-30-2021 08:13 AM
dsnyder586
04-04-2019 02:38 PM
alpecsa
09-07-2015 11:55 AM
AL NZ
09-04-2015 08:39 PM
Sprayall
09-03-2015 07:49 PM
Quick Reply: Fuel gauge reading Half tank when full
