What are these bags under the engine manifold?
Old 05-21-2013, 03:55 PM
harvey_birdman's Avatar
Default What are these bags under the engine manifold?
Was this car used to smuggle heroin? What the hell are those things?
Attached Thumbnails What are these bags under the engine manifold?-61b2925a-2614-4b11-9479-d08ecdebb120-374-000000256eace822_zpsaa11c723.jpg
Patterson (05-22-2013)
Old 05-21-2013, 04:27 PM
Niens2000's Avatar
My money's on heroin because I just checked my X and nothing.
Old 05-21-2013, 04:30 PM
aCapiz's Avatar
Sorry to say it man, but get rid of your car ASAP because it's a drug dealers car. haha jk. I had these in under my manifold and it looks like it was Jag's attempt at heat insulation and trying to keep engine heat away from the air intake manifold. Probably not too important IMO.
Old 05-22-2013, 01:01 AM
Patterson's Avatar
My X also has them. I took a little pinch of the brown stuff in the bags, but it doesn't smoke too well. Burns throat, very harsh!
So it's probably just insulating material.... Honestly, anything that keeps heat away from the intake manifold is welcomed!
Old 05-22-2013, 04:45 AM
grandhaze's Avatar
My s v8 has them except where the rats nibbled, I suspect noise insulation ...because I didn't hear the vermin at work.
Old 05-22-2013, 12:55 PM
disguay's Avatar
very interesting... I at first thought heroin, but now I just think you may need to change your spark plugs because it doesn't look like your intake has been off since the last time it crossed the border
Old 05-23-2013, 06:52 PM
Bruce in North Dakota's Avatar
Location: That Rectangular Hole in the Consciousness of America
Bulletproofing.
(I was thinking of adding more)
Old 05-23-2013, 07:03 PM
ccfulton's Avatar
Received 1,106 Likes on 763 Posts
Yep, it's just boring old insulation, nothing more nefarious than that.
It is supposed to be noise insulation and also is molded on the bottom to keep the valley hoses in their place.
Old 06-05-2013, 08:36 PM
Dang. I was hoping for a score I could sell to my Colombian cousins for big money. Ah well, have to settle for a day job.
Old 06-06-2013, 12:53 PM
bracester's Avatar
Mine does not have it...maybe removed by previous owners...
Old 06-07-2013, 09:47 PM
Patterson's Avatar
The area where these bags sit gets very hot, what do you think? 200°F plus? If you were going to replace them, I imagine you'd have to get them from the dealer because that plastic can handle the high temps.
So the functionality is
Sound insulator
Heat spread away from the intake manifold
and keeps the hoses in place
Not bad!
Old 06-27-2013, 08:52 PM
Bryandreg's Avatar
I had mine removed while at the shop for a new door clip. They said its better not to have them so air can move around and cool under the intake.
Old 06-30-2013, 12:56 AM
Patterson's Avatar
I think removing them or keeping them depends on the weather. Today it was 118F in Scottsdale AZ and I was driving on surface streets with the AC on. The outside temp was so hot that I doubt these thermal insulators were able to do much in the way of suppressing, or diverting heat from the lower half of the engine from getting to the Aluminum cast intake.
On the other hand, in moderate temps (70-80F), they are probably effective at keeping the heat away from the manifold. In even lower temps, including snow conditions, they keep the heat from radiating away from the lower half of the engine, and this is good. A combustion engine loves heat, to a point.
So, I think it 'depends', but for most conditions, they do serve to keep useful heat at the engine block and slow its convection to the intake manifold. Therefor, the manifold may run a little bit cooler for it.
In extremely cold conditions, they are very useful. In moderate weather/temps, they serve well. However, in Scottsdale and Phoenix today where the outside temp was 118F, the heat insulator bags are not doing much. Hot is Hot.
Attached Thumbnails What are these bags under the engine manifold?-xtypeheatinsulatorsunderintakemani_zpse192c343.jpg
toronadomike
08-07-2022 03:41 PM
dsnyder586
04-04-2019 02:38 PM
cissdm
05-03-2016 06:02 AM
TC Johnson
09-02-2015 09:30 AM
Quick Reply: What are these bags under the engine manifold?
