Whining Noise..
Old 02-16-2009, 10:12 PM
JagXTypeEuro's Avatar
Default Whining Noise..
i hear a light whining noise when i first take off to drive at very low speeds coasting at like 10-15mph.. i searched around and see that its more then likely the transfer case or maybe the rear diff. what are the remedy's, fix or maintance that needs to be done.
BTW, hello to everyone, i just recently joined and i have a 02 X-Type 2.5 "Sport Package".. i love the car...and glad to be apart of the forum..
Old 02-16-2009, 10:20 PM
jag-ooo-r's Avatar
welcome.
please take note that more common than a whining t-case or diff is the prop-shaft bearing.
Using the search feature, you'll fine MANY, MANY threads related to each of these noises, which will help you to be a little more sure before you start throwing money at it.
Once you're certain, the "what next" threads are written quite well in the FAQ's, including the T-case and Diff lube change, and the Prop-shaft bearing lube / "to lube or not to lube"....
Old 02-16-2009, 10:50 PM
Received 2,183 Likes on 1,355 Posts
Welcome, and a few things come to mind, T, T, PS, and PASS, trans, transfere case, prop shaft, and passenger. Although the propshaft is more a lower pitch whoooo in a coke bottle...And dont even tell your passenger theyre whining, especially if its your wife.....your seats are comfortable to sit in but not sleep in...
Old 02-16-2009, 10:51 PM
Originally Posted by jag-ooo-r
welcome.
thanks very much for the reply, im gonna go and check it out and see where i stand..
Old 02-17-2009, 06:00 PM
To add to BRUTALS list, at least here in MI, the ever popular rear brake pad drag howl.
Old 02-17-2009, 07:26 PM
lol, thank for the help to you guys.. gonna check it out and see what i got going on under there...
BrentGardner
24
01-18-2021 10:50 PM
PMKimpton
08-03-2019 08:22 PM
1LowCat
02-23-2016 07:19 AM
Johncy2000
10-02-2015 01:05 AM
pk4144
09-24-2015 08:29 PM
Quick Reply: Whining Noise..
