X-Type heated windshield
Old 12-31-2009, 11:14 AM
juge's Avatar
Default X-Type heated windshield
Hi!
Happy New Year to all
Today I noticed that in our X-Type doesn't work the right side of heated windshield. Left side works as it should, but right side doesn't. Just two days ago it worked fine.
I checked fuses, both of them, they were ok. But just in case, I renewed both of them. I found two fuses, in engine bay fusebox, if I remember, they were fuses 14 and 15 and they were 30A. After renewing those fuses, testing the heated windshield, only left side works.
Where the problem can be? Wires / connectors to windshield? Where are those connectors? I remember I have read somewhere about this problem, but I don't remember where there solution at all...
Oh, and just for clearing up, the right side here in Finland is passenger side
Old 01-01-2010, 09:52 AM
mohrd's Avatar
juge, what year is your X-Type? There was a TSB (XT501-036) issued for '02-'05s which dealt with water getting into the connectors (mostly passenger side) for the heated windscreen and a replacement connector C2S 44939 could be spliced into the harness to correct it. Might be your cause. Check with the dealer to see if this had been done.
Old 01-01-2010, 09:58 AM
BuckMR2's Avatar
Mohrd
Will you PLEASE buy an XJ like mine next to advise me and others on the XJ forum whenever we have anything go wrong
Incredible info!
Love the forum and absolutely psssst as car snowed in and house full of booze
Happy hogmanay to Jim too
All the best for next year and this year!
Good luck Aquill with your Police Acadamy exams and driving!!!
Old 01-01-2010, 09:59 AM
jimmy's Avatar
ud
I read a tsb for the heated windsheild.
the connectors are easy to get at after you remove the wiper arms and the black plastic cowl piece. you might be able to get in there like putting a new cabin filter, and test if there is voltage before and after the connector.
If connector is bad, you can just cut it out, and reconnect the wires with solder.
Old 01-01-2010, 10:05 AM
BuckMR2's Avatar
Jimmy
Incredible info!
Love the forum and absolutely still psssst as car snowed in and house full of booze
PS X Types absolutely ROCK and me and my wife really miss mine...if I had my X type even though Im snowed in and wasnt pssst at least I could get out for a drive in the snow now!!!
Old 01-02-2010, 11:32 AM
juge's Avatar
Sorry about that little info about the car.
Car is X-Type, yearmodel 2004, Estate, Executive, and 2.0 diesel.
About that TSB, if it means something about factory-recall-for-repair, I found out some time ago from Jaguar Finland that our car had no TSB open at all (we bought the car second-hand, over a year ago). I googled that TSB number, and it was dated at August 2006, so Jaguar Finland should have known that about a year ago when I made the call...
Well, thanks for that info, I will remove wipers and remove the plastic trim, and check the harness.
Old 01-02-2010, 12:17 PM
mohrd's Avatar
It's not a "recall". There are very few of those on the X. I think the '03 taillights may have been the only official recall. A TSB is a techniical service bulletin that gets issued to the dealers after they have a found a sufficient number of similar customer warranty concerns, what the cause most likely is, and how to fix it.
Old 01-12-2010, 02:05 PM
juge's Avatar
Thanks again about answers.
I found the problem, there was corroded connectors. Opened the faulty side, there was a bit corrode. Cleaned it, and opened the working side, same thing. Cleaned it and now the heated windshield is all working
Old 01-12-2010, 04:09 PM
85_305's Avatar
Heated windshield? Why dont I have one of those? I would think my mirrors would be heated too :scratches head:
Old 01-12-2010, 08:07 PM
mohrd's Avatar
Cold weather package...why don't I have that either? Oh, I know, because I bought the car in Arizona.
Old 01-13-2010, 12:15 PM
85_305's Avatar
Ah that makes sense. My jag is from florida though it now resides in NY. Way to get the shaft again Matt
Old 01-13-2010, 04:17 PM
blackcat's Avatar
You should be happy with your mild climate over there, it's a quite little compensation what we can get with these extras here... Sometimes when supercooled water drops are hitting your windshield, this heating system really is life saver.
Old 01-13-2010, 04:27 PM
85_305's Avatar
Trust me, there is nothing funner than going 70-100mph thru an open field on my snowmobile when the temp is -20*F w/ windchill hehe
Old 01-15-2010, 04:36 PM
blackcat's Avatar
Yeah we are used to do it here in lapland without vizor in helmet... after ride we have a roar of laughter each other when watching our faces with frost and ice Those little things really moves.
Old 10-28-2012, 07:33 AM
cazber's Avatar
I seem to have the same problem, so today I did the same procedure, and tomorrow I will find out if it worked
My problem is that I cannot get the plastic cover pressed close to the windows on each side. It seems fine in the middle part, but sticks out a couple of millimeters on each side of the window.
I am hoping you (or somebody else) have a suggestion on how to do this.
TIA
Karl
42Ajd
12-30-2015 09:45 AM
CaneCounsel007
11-13-2015 09:05 PM
picard
10-12-2015 11:56 AM
10 XF Premium
09-16-2015 09:37 PM
tsimms7
09-15-2015 12:43 PM
Quick Reply: X-Type heated windshield
