X Type Premium audio upgrade (pics)....
Old 07-24-2009, 03:02 PM
BuckMR2's Avatar
Check out youtube
Old 07-24-2009, 06:47 PM
Greenhornet's Avatar
I dropped the Sub/shelf two 6.5 but only one is actual sub, other is radiator. I see the small amp, didn't bother unscrewing shelf/box nothing really to see. Not going to worry anymore about DSP am currious what you think about me switching stock sub/radiator for (two) Kicker 6.5 Midbass subs?
Old 07-24-2009, 06:50 PM
You should be able to drop any 6.5 midbass sub in that spot providing the depth ot the speaker does not go beyond 3". Now the only remaining issue is: are you using the stock sub amp, if so I can't tell you how that amp will feel about the sub. If going after market then you will have no issues at all.
Old 07-25-2009, 05:06 PM
Originally Posted by BuckMR2
Hi Greenhornet
The premium system pre 2004 has a sub and integrated amp in the rear parcel shel the premium system post 2004 has 2 subs in the parcel shelf and a seperate amp beside the CD changer in the trunk
Maybe from what you are saying the pre 2004 premium system doesnt have DSP which I wouldnt have believed before you mentiomed your sysytem doesnt have it????
Ive sent you a PM
I saw your set up your subs are mounted to the deck right? while mine are in a sub box with one sub being a radiator and one real sub. I'm wondering if the box can handle two real subs.
Old 07-25-2009, 06:44 PM
BuckMR2's Avatar
My only sub was a single sub in the trunk RH side wall in a custom fibre glass enclosure.Some .co.uk members who did the upgrade went with the 2 subs in the rear parcel shelf
Old 07-25-2009, 08:24 PM
Seems like many variations but now I'm not 100% sure, I dropped the box to inspect the speakers and wiring but with the box not in the car right now the 10" sub I put in the trunk sounds excellant with nothing there to muffle the sound I'm not sure if I want to put the 6.5 subs back in the car.
Old 07-26-2009, 12:22 PM
Default Which component set
Someone in the Forum maybe U.K. forum I can't remember, posted a note on which component set he recommended but did not recommend the Polk DB series, does anyone remember that article or member please direct me I have to know why he did not like the DB series but rather the MM series.
Old 09-28-2009, 01:15 PM
BuckMR2's Avatar
I found out at a later date that the sub already has the crossovers built in so arent reqd in the doors anyway, maybe this is why I had a PECU..B error after the install that never got sorted unless the amp was disconnected.
  #30
Old 09-29-2009, 06:10 AM
Default Crossovers
I ran the Sub to an aftermarket amp, bypassed stock Sub amp altogether. Since i installed the new component speakers the ONLY problem i've had is replacing the Coolant Reservoir. LOL.
  #31
Old 03-31-2010, 06:51 AM
DavidMoo's Avatar
Hi Buck,
Where did you get the wiring loom from i can get the amp but not the loom as I am looking at also to perform a premium sound retro fit to my x type.
Many Thanks
David
  #32
Old 03-31-2010, 10:32 AM
ufoz8mycow's Avatar
Gaaaaaaaaaaaaaaaaaaaaaaaawd dangit I want your interior
  #33
Old 04-02-2010, 02:45 PM
BuckMR2's Avatar
Re the wiring harness
I bought the wiring harness from x-dave on the uk forum.He made it.He hasnt posted on their for a while and said it was taking too long to make them but I think he may have posted intructions on their to help people making thier own??
Re the seats
They were the main reason for buying the car...the fact that it was a 3.0 manual was a plus too!
Nati
09-25-2015 04:34 AM
ControlIssues
09-03-2015 07:38 PM
MC36
US Lower Atlantic
09-01-2015 07:34 PM
stanjag
08-30-2015 10:35 AM
souldoubt
08-25-2015 08:15 PM
Quick Reply: X Type Premium audio upgrade (pics)....
