Car doesn't start
Car doesn't start
Hello everyone, this my in the forum, this twal1stjag from Va.
I have a 02 Jag X-Type that's been sitting over 9 months. I've recharged battery and gases her
up, still doesn't start . I could use a little help, thx
Welcome to the forum Twal1stjag,
I've moved your question from General Tech Help to X-type forum. Members here with the same model will be able to help.
Received 3,823 Likes
Twal, lets start with the obvious and then we can go further from there. When you roll the key to the START position, does the message center say something to the effect of "Security Fail" and/or the center console has a solid red light? If so, your problem lies with the security system of the car. Write back and we can take things from there.
Next, as you roll the key to the RUN position (not the START), can you hear the fuel pump run for a few seconds and then turn off? If you can't, then it is possible that you have a bad fuel pump from sitting. You can try spraying a little bit of starting fluid into the intake (there is a nice hole to squirt some in right on top of the intake). IF the car fires now and runs for a second or two, then this would confirm a fuel pump issue.
Not to ask a silly question, but does the radio turn on? If not, then you may have a wiring issue where the power to the cabin of the car is affected which will have an effect on the car's ability to start. Along the same lines, then you roll the key to the RUN position, does the "Check Engine" light come on? If no, then your ECU is not getting power and therefore the car will not start.
Lets see what you have at this point and then we can take it from there.
BrentGardner
26
Yesterday 05:19 PM
1964Daimler
09-02-2015 11:41 PM
SingBlueSilver
08-27-2015 02:20 PM
Vector
US Lower Atlantic
08-26-2015 05:36 AM
