High end scanner needed
Old 07-22-2019, 12:13 PM
motco's Avatar
Default High end scanner needed
I have a problem with my X-Type auto-levelling of the HID lights and I am narrowing it down by eliminating each component. However I understand that I shall need to re-code the system once the fault is rectified - whether it is a harness break (likely) or the control module, or a suspension sensor. I am almost 100% sure it's not the stepper motor(s). Where can I get a scanner that includes headlight controls that is Jaguar compatible? The system is Hella and was fitted at least to the S Type as well. I am in UK but can source from abroad if need be. Thanks chaps!
Old 07-22-2019, 04:07 PM
Dell Gailey's Avatar
SEARCH is a marvelous tool =
https://www.jaguarforums.com/forum/x...rogram-167246/
I'd also contact iCarSoft directly and see if their LRII will do the same. I know it does abs, srs, epb, sas, I/M, EVAP, o2 sensors, module toggling, ecu reading, etc
Old 07-23-2019, 01:24 AM
motco's Avatar
Thanks Dell, I should have mentioned that I had found that thread but Lancer hasn't been on the forum for long time and I cannot see a way to send him an email or personal message. It may be that as a new member I cannot use those functions yet. Many thanks, though, for making the effort to help. I shall contact iCarsoft as you suggest. I already emailed Launch and Diagnostic World but with no replies as yet.
Old 07-24-2019, 03:28 AM
motco's Avatar
I have replied to your post Dell, but it hasn't appeared yet. I am a new member so they want to make sure I'm not a troll before they allow me to contribute I think.
westway
21
11-16-2019 01:44 PM
hamzaisl
General Tech Help
05-14-2017 04:34 AM
Spedracr15
05-24-2011 06:08 PM
wolv2401
07-21-2009 10:47 AM
jvegas
05-15-2008 11:47 PM
Quick Reply: High end scanner needed
