cruise not available
Guest
Posts: n/a
2002 X-type - 62k. No problems before this. Now I have an intermittent message: Cruise Control Not Available.
But... Cruise control works fine. Message comes on every few minutes but Check Engine light remains on.
I changed the battery about 6-weeks ago. But electronic bugs cleared up within the first day. Checked all fuses and connections. Everything good and tight.
Any idea what's going on? or... how to reset the system without a trip to the Dealer. I do all the maintenance myself. - Thanks
Guest
Posts: n/a
RE: cruise not available
i only go that with the check engine light.. turns out the thermostat was acting up and the car was running hot then cold... that set the check engine light then occasionally the car went into limp mode and that gave the message cruise not available..
has not happened since the new thermostat.. but the point of this message is that you should probably find out what is setting the check engine light..
changing the battery should not cause any problems... just the radio code and the toll feature on the power windows..
Cruise unavailable is just a soft code, meaning that there is a bigger issue that has yet to show itself. The reason it says cruise unavailable is so that if your jag goes into limp mode your not locked into a high speed. When your jag goes into limp mode it locks itself in 3rd gear...If your on the freeway, in cruise, doin 75 then down shifting into 3rd gear would be not good...
Sounds like your gonna need to get your jag diagnosed??
could have a sub processor failure. the pcm has 2 processors. the main (outside processor) and the sub processor (this controls throttle and cruise)... it could be a simple patch file that needs to be loaded. you will have to find someone with wds/ids to diag it for you. or take it to the dealer.
without pulling all codes, you are just guessing at it! it could also be a bad battery. the negative terminal likes to crack and corrode on the xtype and can cause some voltage related issues.
Received 9,005 Likes
Guest
Posts: n/a
keep in mind that mercedes are the taxi of choice in most of the world.. they are good long life cars, low long term running costs and certainly are not loaded with accessories for taxi duty.
only the US demands accessories..dominate as the americans are.. they are not the world majority.
I wish that more euro cars were available stripped down and afordable. If you want acheap car here you need to drive something crappy.
that being said.. my car is loaded with everything EXCEPT auto transmission
Ohhhhhh........listen to Andersen...(slap) goin on about cruise control an how he's got it.....lol
Well, Bo's right........only in the states do you guys demand everythin as std.......over here we have lower standard base models then lots of possible options, which means you can buy exactly the car you want, or indeed the car you can afford!
Therefore you end up with many more possible choices than I guess you guys have.
Anyway Andersen, stop bein b*tchy, its not like you.
Did you get outta wrong side of the bed this am or what?
Oh yeah.........I've got bright lights and can at least see where the h*ll I'm goin....... whats your excuse?.........lol
Jim C
Its easy to forget some of you are from across the pond. And us americans have been spoiled by many enjoyments. I would love to buy my cars the way you guys do, but I dont make the rules. And Im just saying...Cruise should never be a option, It should be a standard. Leave the options for cup holders and heated seats(which I have).
ORIGINAL: andersen06
No heated seats either, but it doesn't get that cold over here......"lying thru teeth"
Jim C
FS[NorthEast]: 2008 XJ Super V8 - Black on Cream
sg997tt
10-09-2015 10:57 PM
