front indicator fault driving me mad
Old 05-05-2016, 09:47 AM
statuskev's Avatar
Default front indicator fault driving me mad
Hi there I have a jag x type estate 2.0 diesel estate with a problem so any help would be appreciated.
The front passenger side indicator will not work,bulb has been changed and checked bulb holder for continuity all OK.Checked the earth to the lamp and that looks OK but can't detect 12 v to lamp when in use.All the other lamps are working fine so now stumped,advice please.
Old 05-05-2016, 12:43 PM
iownme's Avatar
Are both front indicators using the same ground?
If not, try connecting a wire from driver side ground to pass side ground.
I assume you r talking about indicator inside the headlight
Old 05-06-2016, 01:39 AM
JagV8's Avatar
Received 4,484 Likes on 3,902 Posts
First check circuit diagrams as much of the car is negative switched so the above would cause more faults.
Old 05-06-2016, 05:27 AM
avern1's Avatar
Received 1,317 Likes on 1,004 Posts
You had said you checked for power and there was no power on thewire for the turn signal. Have you engaged the hazards flashers and checked for operation?
If the rear light works with the turn signal then the signal stalk is operating correctly. If the turn signal lights with hazard switch then the wiring is good.
If the light doesn't work with the hazards then you need to check for a crack or break in the wire to the bulb.
If the light works with hazard then probably the fault lies with the GEM general electrical module.
Old 01-18-2018, 08:49 AM
Bootneck40's Avatar
Default Same problem
I also have exact same issue could anyone help please
Tomica
Other Areas
09-20-2017 01:50 AM
Bhpbug
05-03-2016 12:26 PM
alynmurray
04-04-2016 10:12 AM
buttpt
03-31-2016 04:48 PM
steve12955
03-27-2016 05:09 PM
Quick Reply: front indicator fault driving me mad
