Need ACM
They do come up on Ebay every so often(in UK anyway) or get a parrot kit like this:
Home / Parrot Shopping / USA
This is the part # for the X Type ACM. C2C 40513.
Keep checking ebay, or check your local Jag dealer. There are some still around. Look to pay around $400-$450.
If you find one they are an easy install. You'll have to remove the center consol, which can be tricky.
I have a Sirius radio fed through the RCA jacks in the ACM set up.
Good luck.
Good luck.
Good luck.
Good luck.
acm
i researched the acm..far too expensive..i bought a good quality in car fm 12v modulator from evilbay..its pretty good..has a built in ground loop supressor so cuts any noise..i also got a boostaroo ..small inline amp for low levels ..as mp3s can be sometimes too low.
there was the option of an aftermarket stereo but a guy i work with fried the ecu dickin around putting in the new stereo ..had to get jaguar reflash the ecu..although he is a bit dumb.and im an electrician by professian..i went with veba fm modulator in the end
