Performance upgrades??
After briefl looking thru topics here...and searching and searching the web...I cannot find performance upgrades for the X Type....or suppliers of parts...maybe Im not looking hard enuff or in the right spots.....any help or links to sites....(if allowed) would be helpful....or link to threads.......granted its my wifes car....but Im a long time muscle car owner...and granted I got a Mustang to Mod...and I have........I wanna do some mild things to the Jag......Mufflers......Cold-Air.....grille inserts.....maybe wheels and tires...rotors....let me know guys....want to enhance the beautiful looks of the Jag...and make her purrrrr......
www.minagallery.com has most of what you are looking for. The cold intake may or may not throw CELs and codes. The exhaust is really only the back boxes and tips. If you want a real different sound, you can always look at doing custom exhaust. If you are looking to beef up the horsepower, most of us will chime in with the same thing...the transfer case will not take the stress.
you can get rotors off ebay from $150 to $300 plus depending on how much you wanna spend...pads are the same up to $100 or so for the front..rears are a little cheaper. K&N filter . ive seen chips on ebay sometimes but ive heard you have to be careful getting those ebach has a spring/strut kit other than mina already mention this is about it
Received 9,005 Likes
Hey there....check out Mina gallery, nameless performance who is a member / vendor here on site.
Exexpat - check out his profile amongst others for lowered cars with meaner sounding exhaust notes and EBC slotted / grooved rotors with EBC Redstuff pads or similar
Upper n lower mesh grille inserts or the newer 09 grille, maybe adda bootlid psoiler if it doesn't have one and a few other bits n pieces.....loads of members to help with ideas
What I have done to my X-Type
I see some mention doing brakes and other performance upgrades. I have a 2004 Jaguar X Type 3.0. It currently has 94120 Miles on it. Also it is in the shop with transfer issues. I should be getting her back by the end of this week. As of right now I have installed Brembo rotors and pads all the way around. I will soon need new rear calipers as hand brake efficiency is close to nill and the rear caliper handbrake lever is seizing up presenting play in the handle itself. I just purchased the required materials to install a new intake and cone filter. 2 weeks ago I had the resonator removed and am planning on replacing the mufflers here soon after the intake is complete. I have done all of the work my self with the exception of the exhaust work. And of course the transfer case.
What has been done:
HIDs: Kensun
55w 6K High Beam
35W 8K Low Beam
55W 12K Fog Lights
Sound System
Head Unit:
Pioneer Fh-x 820bs (Double din w/ Bluetooth)
Speakers (Front & Rear):
Pioneer TSD1602R (2 Way 6.5" Speakers)
Amp:
Alpine mrv250
Subs:
2 12" JL Audio 12W4
Brakes
Front:
Pads:
Brembo P24060N
Rotors:
Brembo 09.8665.11
Rear:
Pads:
Brembo P24063N
Rotors:
Bremebo 08.9734.11
Headliner Replaced
New Door Panel Pins/Clips:
Ebay (here)
What I'm Planning on doing/having done:
Mufflers
Window Tinting
Aftermarket Facelift Mesh Grill
H&R Sport Lowering Springs (1.3" Rear & 1.4" Front)
18" Rims
OR
Rims: Niche Form M157 19X8.5
P.S. For the HIDs get 55w for all. Having them installed i now wish I had had gotten the higher wattage. Also, dont worry about the heat melting the housing w/ the 55w. I have been running these lights for a year w/ no issues.
What has been done:
HIDs: Kensun
55w 6K High Beam
35W 8K Low Beam
55W 12K Fog Lights
Sound System
Head Unit:
Amp:
Alpine mrv250
Subs:
2 12" JL Audio 12W4
Brakes
Front:
Pads:
Brembo P24060N
Rotors:
Brembo 09.8665.11
Rear:
Pads:
Brembo P24063N
Rotors:
Bremebo 08.9734.11
Headliner Replaced
Ebay (here)
Mufflers
Window Tinting
18" Rims
OR
Kota62 (06-30-2015)
Received 3,825 Likes
Jcwike, just a note on the 55W HID bulbs. Please note that the 55W HIDs are not DOT rated. Therefore, having them installed is technically illegal in all 50 states. Only the 35W bulbs are DOT rated. I know there are people running around with the 55W bulbs installed, but that doesn't make it right. It is a lumen output issue. Yes, it may help you see, but you are also blinding those coming at you too with the 55W bulbs.
If you are looking to upgrade the calipers, take a look into the ST225 calipers. That will give you a multiple piston setup that should be a direct bolt on upgrade.
i did a resonator and muffler delete it not too loud but has a nice growl foreign
E=triumph_013;269250]I've been contemplating the idea of a custom 2.5" or 3" exhaust, straight piping from the cat back with a resonator. I'm don't really want to be the guinea pig on this though, has anyone else done a similar exhaust set-up on their X?[/QUOTE]
rominempire
28
10-08-2020 10:39 AM
