right front side marker bulb replacement x type
Received 3,825 Likes
Robin, form the sounds of things, your metal clip has gotten bent and will need a little tweaking to get it back to where it should.
In short, when you put the plastic hook in first, this should leave the metal clip sticking out part way. If you push the light housing in a little more (leaving about a 1/4" gap on the metal clip end), you should see where the clip starts to hit the plastic of the bumper. if you are getting too far away, it is possible that someone tried to pull the light housing out the wrong way and pulled the clip away. A pair of needle nose pliers should allow you to bend the clip back to where it should be.
Hey guys,
I see that this post has a pretty new entry, so I figured maybe I shouldn't create a new post.
I'm looking for the part that is on the attached image. I really don't know the name of it, but it's the "holder" for the front (passenger) marker light bulb. I've tested and the bulb works just fine, so it should be just the "holder".
Sorry if I'm not being precise, but English is not my mail language, so I wouldn't know how to start looking.
BTW, I live in the US, which might be a drawback.
Thanks in advance!
EZ
Thanks in advance!
EZ
Try these used eBay parts for $10 and $12:
2002 2005 Jaguar x Type Fender Side Marker Light Bulb Part | eBay
02 08 Jaguar x Type Fender Side Marker Light Bulb | eBay
zaidmanemilio (08-23-2016)
I've just bought some wire connectors (https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1), but I don't know if they'll fit. If not, I'll definitely try one of your options.
Thanks again.
EZ
#28
F63 and F64 (L & R) for your model year. When you say not working, you are aware they are blinkers not steady illumination?
Fuse box diagram attached
https://knigaproavto.ru/shemy/en/jag...x-diagram.html
h2o2steam (09-06-2022)
BKSinAZ
07-29-2017 03:03 AM
