Window switch lights
Received 3,823 Likes
Jaggy, the best advice that I can tell you is to pull the window switch out and see what you can do about replacing light bulbs. I would also put a multimeter on the orange wire to ensure you have voltage there (the voltage present will be directly related to how bright you keep the dash lights, this is where dialing the lights up all the way will make diagnosing easier as you should be pretty much at 12.0 VDC).
99xk8guy
06-05-2023 06:28 AM
